FAULT CODES advice please anyone !
Posted: Sun Oct 21, 2018 1:31 pm
ok a number of fault codes have came back from my car, for those who are not aware of my issue please read my other post first but in short some days my car will start perfectly fine, some days when I have a warning light showing the car will turn over but not start up. All this has been explained in my previous post so I wont bore you with all that.
So these faults, very strange, some faults showing I have absolutely no issue with ?? so those I cant understand, and only 3 I would say could possibly be the fault but again I really don't think so but that's why im asking for advice, I will show the results of 3 scans, explain what I think below each and if anyone can advise then please do.
1ST SCAN ENGINE OFF / IGNITION ON
i wont list the full scan, so first faults are as :
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00021
Shop #: WSC 06335
VCID: 3D7F3928375649A2FE-4B18
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
30-00 - Open or Short to Plus
02746 - Bulb for Daytime Running Light; Right
30-00 - Open or Short to Plus I am aware of this as ive not replaced the upgraded bulbs just yet
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 C HW: 8E0 920 983 C
Component: KOMBI+WFS 4 H14 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0023448
Shop #: WSC 54516 001 1048576
VCID: 2F631360BD3AAB327C-5178
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
01321 - Control Module for Airbags (J234)
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication - Intermittent ok the bottom one CMR is the actual light that when shows on my dash the car will not start BUT this fault if indeed was the issue would not stop the car starting up, so I can only assume this is showing because the light does/has shown up on my dash previously so that doesn't help matters really, no idea what ECM does and would this stop my car starting ? and the CMA again would not stop my car starting.
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023448
3 Faults Found:
004 - No Signal/Communication - Intermittent all 3 faults showing again
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H73 0650
Revision: 02S Serial number: AUZBZ7F1169935
Coding: 0309113
Shop #: WSC 02197 785 00200
VCID: 2C59046C8C2CD02A59-51B2
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 114
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Clock: 09:34 ???????????????????????? ERM NO IDEA WHY THESE ARE SHOWING i have no issue with any of these, very strange
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07919
Shop #: WSC 06335
VCID: 79F7ED3863FEB58292-4B18
Subsystem 1 - Part No: 8E2959802E
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
36-10 - Open Circuit - Intermittent Alarm has only ever gone off once when a mountain bike was stolen from the bike rack on the back of my car, no idea what the crash bit is all about ?
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Clock: 09:34 AGAIN, i dont sem to have any of these issues so why are they showing ?
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02195 823 21170
VCID: 2A55027486D8CE1AAB-5178
1 Fault Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 48
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 70.0
Voltage: 13.40 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn. again this seems to work fine, when dash light says top up tyre pressures i do, all seems to work fine, no idea again why these are showing
SO THAT WAS SCAN 1 ingnition on engine not running, scan two next
Coding: 00021
Shop #: WSC 06335
2 Faults Found:
Coding: 0023448
3 Faults Found:
Coding: 0023448
3 Faults Found:
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Coding: 07919
Shop #: WSC 06335
2 Faults Found:
35-00 - -
Coding: 0309113
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 62
Time Indication: 0
Date: 2017.03.22
Time: 09:06:17
Freeze Frame:
Voltage: 12.30 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Reset counter: 57
Time Indication: 0
Date: 2018.09.07
Time: 11:11:12
Freeze Frame:
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 61
Reset counter: 58
Time Indication: 0
Date: 2017.04.28
Time: 16:05:58
Freeze Frame:
Mileage: 655350 km
Count: 2110
Coding: 0022523
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 48
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 70.0
Voltage: 13.40 V
(no units): 61.0
Not Recogn.
Not Recogn.
Not Recogn.
