audi rs4 battery
audi rs4 battery
hi new to the forum im having trouble with audi rs4 battery draining and not starting after a couple of days stood the battery is only 6 mths old has anybody else had the problems thanks rob.
- 2nd Gear
Re: audi rs4 battery
Measure the charging capacity on idle, should be 13,4-14,0 volt on battery. Can be a faulty alternator
@softishman on IG
Check out my RS4 there!
ok mate thank you will try that its frustrating because the battery is showing fully charging when ticking over but drops when engine is switched off.
Any aftermarket alarm in it?
Mine was killing the battery took got it sorted
hi mate im not sure it has i think its stock but will check anyway thanks.
Users browsing this forum: Google [Bot] and 449 guests
