Coolant tank condensation
- 2nd Gear
Hi guys,
Is it normal that I fitted new coolant tank and cap but just noticed that the condensation still too much and still loosing coolant. Not much but the last 3 weeks i topped up 1liter.
Aux rad fine
No coolant fluid under the car.
Radiators fine no leaks at all.
After cold start is a bit lumpy but just 2-3 minute.
Any idea?
Aux rad fine
Any idea?
Re: Coolant tank condensation
Get it gas checked just to be sure?
these are old cars now and some of the plastic and metal pipework can suffer-best to run with undertray off for a while in an attempt to identify,it gets hot under the bonnet so a small weep will just evaporate ,perhaps leaving a little white stain
the cars shouldnt use any coolant at all
- 2nd Gear
Hopefully nothing serious
Was it ready mixed or did you use concentrate? If so did you use distilled/de ionised water?
- 2nd Gear
Ready to use
Defo not the aux rads? Might still look OK with just a visual.
- 2nd Gear
One was broken then I fitted cold air feed. Other auxrad still perfect condition
What about where you blocked your removed aux rad for the cold air feed. Is it sound?
- 2nd Gear
When we fitted was ok but I will check today again but I haven’t seen any water leak from there.
- 2nd Gear
So the issue was that T pipe which connecting in to the manifold. The old clamp wasn’t enough hold the pipe.
Hey well done, nice simple fix
Users browsing this forum: nickwigan and 215 guests
