Coolant tank condensation
Hi guys,
Is it normal that I fitted new coolant tank and cap but just noticed that the condensation still too much and still loosing coolant. Not much but the last 3 weeks i topped up 1liter.
Aux rad fine
No coolant fluid under the car.
Radiators fine no leaks at all.
After cold start is a bit lumpy but just 2-3 minute.
Any idea?
Aux rad fine
Any idea?
Re: Coolant tank condensation
Get it gas checked just to be sure?
these are old cars now and some of the plastic and metal pipework can suffer-best to run with undertray off for a while in an attempt to identify,it gets hot under the bonnet so a small weep will just evaporate ,perhaps leaving a little white stain
the cars shouldnt use any coolant at all
Hopefully nothing serious
Was it ready mixed or did you use concentrate? If so did you use distilled/de ionised water?
Ready to use
Defo not the aux rads? Might still look OK with just a visual.
One was broken then I fitted cold air feed. Other auxrad still perfect condition
What about where you blocked your removed aux rad for the cold air feed. Is it sound?
When we fitted was ok but I will check today again but I haven’t seen any water leak from there.
So the issue was that T pipe which connecting in to the manifold. The old clamp wasn’t enough hold the pipe.
Hey well done, nice simple fix
Users browsing this forum: Hurky and 177 guests
