Standard disc dimensions
Does anyone have a standard rear disk which is new or nearly new that they can confirm the dimensions i have? Im getting some 2 piece discs made up and just want to make sure what i have is correct.
- Attachments
- 1 - STANDARD REAR DISC - Rev 1.pdf
- (24.99 KiB) Downloaded 50 times
2007 B7 RS4 Saloon, Phantom Black, Forge Oil Cooler Kit, custom home made air feed, H&R Coilovers, H&R anti roll bars, 10mm H&R Spacers, Milltek decat downpipes, Milltek Non Res Valved Exhaust, Reyland Motorsports front & rear discs with Hel braided Hoses, full underbody overhauled inc powdercoated subframes and arms, 034 solid subframe bushes and every joint, arm or bush replaced.
Re: Standard disc dimensions
Who's making them for you.....Reyland?
Yes they are, going to work out the cheapest way to replace all four discs, should work out £950-1000 for all discs
That’s not bad. How did you get on ?
Current Toys -
B7 Audi RS4 Avant - Phantom Black
E92 DCT M3 LE500 - Imola Red
Navara NP300 Tekna
E36 BMW M3 Evo track Car - Cosmos Black
Navara NP300 Tekna
Had a bit of a delay with these, instead of going with the drawing i sent they have bought a new rear disc to take the measurements off, all discs are made so just waiting for them to press go on the cnc for the bells and then get the bells anodized, they have said id get them this week.
What was the final cost if you don't mind me asking?
£550 for the rears and £340 front plus £20 postage, the discs and bells were finished on Thursday evening but with the bank holiday wouldn't be with be until this Tuesday, I have asked him to delay postage for a day on top as we are away for a couple of days.
Keep us posted on your thoughts when they’re fitted and been used mate.
Will do, im not expecting them to be any different from stock though due to them being the same size, might have better cooling maybe, a friend of mine has a 400+hp civic with reyland discs and they have held up well.
They don’t do drilled options do they? Did you go for slotted or hooked?
Thats right they only do slotted in straight curved or hooked, i have gone for hooked
picked my discs up today and had a quick trial fitting (i arent fitting them until i have got my garage tidied up and can get the car in to paint the calipers etc) all seems good, the discs sit in the same position within the carriers and im pleased with them!
They looks great. Look forward to seeing them with the painted Calipers and fronts done and hearing how they perform and hold up over time.
Users browsing this forum: Bing [Bot] and 85 guests
