Hi chaps,
Just doing an oil change.
I've removed the oil filter and cap but struggling to separate the filter from the cap.
Is there a technique to it?
I thought it should just slide out.
Cheers for any advice!
Mike
Sent from my Nexus 5 using Tapatalk
Help! How do you remove the oil filter from its cap?
Re: Help! How do you remove the oil filter from its cap?
It's clipped in with those tangs . Look at the new one should give you an idea. Just give it a good pull and it will seperate.
Cheers Dhali - got there in the end with a bit of brute force.
Sure I'm getting weaker with age...
Anyway, all done now, about 8.5 litres out so happy with that. I'll give it a run out and check all is good.
Mike
Mike
Users browsing this forum: No registered users and 566 guests
