If i disconnect the batter ?
If i disconnect the battery and remove the steering wheel will it put and lights on the dash when i connect it all back up again ?
Stage 2 mrc, Pre cats removed, Milltek Resonated, Bilstein B14 Coilovers, MRC De carbon, Deflapped MRC, RR 434BHP, Pandora alarm system, 8mm Rear spacers
Cold air feed, Refurbed caliper colour change, Carbon piller, Carbon dash ends
Re: If i disconnect the batter ?
Yes, you need to reset the airbag light
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
I thought it would only do that if you reconnected the battery and turn the ignition on whilst the steering wheel / airbag is off.
I’m not sure Mike. Every time I have disconnected the battery and removed the steering wheel I have had to reset the light. Not sure if the order though. ESP light will be on top, although that will turn itself off at some point.MikeFish wrote:I thought it would only do that if you reconnected the battery and turn the ignition on whilst the steering wheel / airbag is off.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
OK I've not tried the steering wheel, but I know if I remove the seats then put them back in before turning the ignition on I don't get any warnings, but if I turn it on with a seat out I get the air bag light.
I didn't get the airbag light on when i removed the airbag. I fitted the rs4 badge into the ttrs wheel which is fitted on mine .I disconnected the battery - ve lead . Keys out the ignition . As Jon j says esp light will come on but reset itself after a few hundred yrds .
I didn’t get any lights on my C6 RS6 when I changed the steering wheel buttons which involved taking the air bag off. I didn’t disconnect the battery either.
Brave! LolHouse89 wrote:I didn’t get any lights on my C6 RS6 when I changed the steering wheel buttons which involved taking the air bag off. I didn’t disconnect the battery either.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
I consulted Tim @ The Phirm and he assured me it was safe. I wasn’t totally reckless!!Jon_J wrote:Brave! LolHouse89 wrote:I didn’t get any lights on my C6 RS6 when I changed the steering wheel buttons which involved taking the air bag off. I didn’t disconnect the battery either.
I changed steering wheel & airbag on Golf IV and just made sure the ignition wasn't turned on and no lights came on. I have VCDS so could have reset if necessary but it wasn't.
Users browsing this forum: No registered users and 243 guests
