ARB C Links - Genuine / Pattern / Up Rated bushes?
The bushes in my ARB C Links are going to need replacing soon. I only use the car for road use. Genuine parts don't look like they will break the bank , but do you guys have any recommendations on what to replace them with.
2006 Misano Red RS4 Saloon.
Re: ARB C Links - Genuine / Pattern / Up Rated bushes?
i used meyle hd for all my suspension arms,links etc
every bit as good as o/e imho
Those kits do look good value.
As I only needed the c links I went for genuine with a decent discount from TPS.
inc the two lower arms each side i was mid £300 for upper,lower arms and the two c shaped droplinks iirc
this and the new set b14 freshened the car up well
i didnt replace the track rod ends as there was zero play-but any decent quality item will be fine for a track rod end as there is no rubber bushing
Do you have a link to where you sourced your meyle parts from?
i just trawled through ebay tbh-there is a post on here somewhere with all the part numbers too-it was handy in my search....
viewtopic.php?f=35&t=126018&p=859996&hi ... hd#p859996
I’ve just purchased a full set of Lemforder OE front arms (8 in total) from autopartstechnik for £560 inc VAT & delivery to Northern Ireland. Meyle HD is cheaper, I just preferred sticking with OE supplier. I would recommend autopartstechnik, best price I could find and very prompt delivery.
main thing no matter what you buy-tighten them up with weight of car on suspension-not while jacked up and dangling...biggest cause of premature failure
Users browsing this forum: No registered users and 255 guests
