B7 Rs4 brake fluid change help needed
SamRs4
Post by SamRs4 » Wed Feb 21, 2018 7:21 pm
As the title says wanted to no how often you have to change the brake fluid,had new discs and pads last year so had Mrc do the fluid to since then only done about 500 miles and the cars been in the garage since December will be back on the road in April service is due so back to mrc just wanted to no should I get the brake fluid done to ?pls advise thanks
dhali
Re: B7 Rs4 brake fluid change help needed
Post by dhali » Wed Feb 21, 2018 8:52 pm
every three years iirc.
Covkiller
Post by Covkiller » Fri Feb 23, 2018 3:37 pm
I do mine every 2 to 3 years. If you do change the fluid buy lots. As last time I flushed mine twice and the difference is amazing. After the 1st flush I drove it for about 50 miles then the next day flushed it again. The different colours and crap that came out was an eye opener. I know it costs more but its worth it.
Mav8
Post by Mav8 » Fri Feb 23, 2018 4:22 pm
Great advice,any preference on fluid?
Mav8
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Covkiller
Post by Covkiller » Fri Feb 23, 2018 4:28 pm
I run Ferrodo DOT 5.1. Many will say this is not compatible but I have had no issues whatsoever in both of my B7 RS4's. The reason I went for this is that the standard DOT 4 fluid in my original RS4 started to boil over on a 42'C day after a lap at the Nurburgring. So I went for the higher spec.
FaisalJ
Post by FaisalJ » Fri Feb 23, 2018 6:26 pm
Aha ! Brake fluid thread
I can break out this handy chart I nicked from another forum
2007 RS4 B7 Avant
Covkiller
Post by Covkiller » Fri Feb 23, 2018 7:07 pm
Well done Faisal very handy :thumbs:
dhali
Post by dhali » Fri Feb 23, 2018 9:38 pm
Get yourself a sealy vs820 brake bleed kit. It's a doddle changing the fluid with it . Just be careful not to pressurise the system too much or you will split the brake fluid reservoir.
BenHol
Post by BenHol » Wed Feb 28, 2018 3:29 pm
how much brake fluid do these hold, iv just ordered 1 liter?
RS4 B7 - Phantom Black, 20in RS6 C7 alloys, Joey mod, detango, led drl, black optics, Bilstein b16, Michelin ps4s, centre res delete, black tips, 8mm spacers, vx lenses, RS embossed xenon, Carbon splitter, 034 ARB.
dhali
Post by dhali » Wed Feb 28, 2018 8:21 pm
I Think Capacity Is 1LTR , But You should Buy 2LTRS Just To Make Sure You Flush everything out. You will probably end up using 1.5 lts . I normally buy 5ltrs as I've another car to do so works out cheaper . I also use a syringe to suck out the old fluid out the reservoir first and add fresh fluid ,then attach the bleeder. Might be uneccessay but was told you have minium mix of the old and new fluid in the reservoir . But if your using the blue fluid and vise versa its not necessary.
I've not tried what covkiller has suggested but will next time as he has said there was a remarkable difference again after 50 odd miles .
Users browsing this forum: Bing [Bot], Google Adsense [Bot], JamesBaby, Leask, lugars4, Mav8 and 93 guests
