found these decats from Germany and wondered if anyone here has them? They work out at £393.50 delivered so not a bad saving compared to milltek, however awesome gti have 10% off at the moment making milltek £483.
http://www.fahrzeugtechnik-zinram.de/ep ... P-RS4b7-OK
Cheaper decats
Cheaper decats
Re: Cheaper decats
I have had zinram 100 cell cats and the the overall fit was on but the cone on the tube is little long so the bracket doesen’t come as high that i wanted making the pinnbolts a little short...
@softishman on IG
Check out my RS4 there!
Re: Cheaper decats
Couple of good finds there, I’m looking for a decat solution for my rs4 at the moment. I was thinking of getting some used original down pipes and gutting them completely, could be cheapest option if you can do the work yourself?James1984 wrote:found these decats from Germany and wondered if anyone here has them? They work out at £393.50 delivered so not a bad saving compared to milltek, however awesome gti have 10% off at the moment making milltek £483.
Re: Cheaper decats
I looked at gutting a set of origional downpipes mainly for aesthetics incase i ever get stopped by the boys in blue but thought the flow of proper decats might be betterAndyevo wrote: ↑Sun Feb 18, 2018 8:22 amCouple of good finds there, I’m looking for a decat solution for my rs4 at the moment. I was thinking of getting some used original down pipes and gutting them completely, could be cheapest option if you can do the work yourself?James1984 wrote:found these decats from Germany and wondered if anyone here has them? They work out at £393.50 delivered so not a bad saving compared to milltek, however awesome gti have 10% off at the moment making milltek £483.
Re: Cheaper decats
Ordered a set of milltek decats with awesome gti and had my order cancelled as apparently milltek have stopped production of them, managed to get a set off the shelf from roadrunner Motorsport which I believe was the last set they had.
Users browsing this forum: No registered users and 143 guests
