Rs4 battery issue
- 2nd Gear
Rs4 battery issue
My battery flat for 2nd time after leaving the car for few hours so I think time to change the battery...Do I need to coding the new battery? Or just plug in? Which battery will be the best? Exide?
Re: Rs4 battery issue
plug in-just buy a battery with decent warranty[3 yrs or so]
if there is a euro car parts near you they usually have an offer on
i wouldnt buy mail order -in case you have to return it-not often you get a dud but it does happen
- 2nd Gear
Yeah 33% off euro carparts
I got mine from Euro Car Parts a few weeks ago, same day delivery, ordered at 10am and it was with me by 2. Most impressed
RS4 Cabriolet - Phantom Black with Exclusive interior
- 2nd Gear
How much u paid? And which battery u have? 110a?cherub72 wrote:I got mine from Euro Car Parts a few weeks ago, same day delivery, ordered at 10am and it was with me by 2. Most impressed
- 2nd Gear
I couldn’t find cheaper than 250
This is the one https://www.tayna.co.uk/car-batteries/varta/i1/
Rs4 phantom black b7 avant : Mrc tuned
I changed mine just recently - easy swap over you will need to re-sync the remotes and wind the windows up & dowm so they learn again.
I went for the Duracell one, had the best warranty and the price was pretty good too, helps that I picked a day when they were doing money off. Came in around £120 with deliveryGary(rs4)87 wrote: ↑Mon Feb 05, 2018 11:20 pmHow much u paid? And which battery u have? 110a?cherub72 wrote:I got mine from Euro Car Parts a few weeks ago, same day delivery, ordered at 10am and it was with me by 2. Most impressed
- 2nd Gear
I went for bosch s5 but still not swapped yet because now the old one is working.
- 2nd Gear
How can I resync the remote?MB2 wrote:I changed mine just recently - easy swap over you will need to re-sync the remotes and wind the windows up & dowm so they learn again.
It should be as simple as put the key in the ignition, turn to the accesory position (ie light up the dash but don't start the car) and then press the button on the remote, switch the ignition off & test.
That is what I just did with all my keys - I think locking & unlocking the drivers door and pressing the button may also work but ignition key is easy enough.
You can also sync using VCDS but that worked perfectly for me.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 231 guests
