Headlight washers
Posted: Wed Dec 20, 2017 9:49 pm
by SimonS4MTM
So it appears my headlight washers do not work. Not worked since I got the car in April - yes I have only recently tried them.
I can't hear the pump working so I am assuming the problem is either with the pump, or with Vagcom coding. I have checked the coding tonight, and I am a little confused.
Vagcom says that the standard coding is 115. It turns out my coding is 114. I have tried a coding of 114+32 and 115+32 and still no headlight washer activation. Also what is odd is that my rear wiper works when in reverse which also does not tally up with the coding value.
So, is the Vagcom coding a red herring and should I not worry about it, or should I check the pump?
CheeRS
Simon
Re: Headlight washers
Posted: Wed Dec 20, 2017 9:53 pm
by Jon_J
Mine had this issue when I got it. I took the bumper off and ran a feed to the pump in the bumper, it didn’t do anything. I gave it a wallop and it started working. Go through it methodically.
Unlikely the coding is incorrect.
Posted: Wed Dec 20, 2017 11:06 pm
by Gary(rs4)87
Mine is not working, so it will be checking this week because need to book for MOT soon
Posted: Mon Dec 25, 2017 11:22 am
by cocovs6
Fixed my headlight washers recently. Had to replace pump which had corroded. Pump sits on passenger side in front of wheel arch. There is two pumps on washer reservoir; one for headlight and other for windscreen. Take the wheel arch liner off and see if any corrosion on pump and check pump operation from there.
Posted: Mon Dec 25, 2017 6:25 pm
by Lukes3
Just before you start taking things apart,
You are trying it with the headlights switched on?
Posted: Tue Dec 26, 2017 7:49 am
by cocovs6
Good shout!!!!
Posted: Tue Dec 26, 2017 1:09 pm
by Jon_J
Lukes3 wrote:Just before you start taking things apart,
Haha I thought that went without saying but good shout.
Posted: Tue Dec 26, 2017 3:43 pm
by Lukes3
:thumbs:
Posted: Tue Dec 26, 2017 8:00 pm
by SimonS4MTM
Err yes. Headlights on.
Posted: Tue Dec 26, 2017 8:02 pm
by SimonS4MTM
So no need to remove front number to change the pump then?
Posted: Tue Dec 26, 2017 10:07 pm
by Lukes3
If the headlights are on an they are still not working, yes you will need to remove the bumper an have a look, ( this is how i done mine)
I also needed to replace the pump for them as mine had seized,
