420mm discs
Posted: Thu Dec 07, 2017 6:54 am
by Tommcole
Hi Guys
Has anyone tried to fit 420mm discs on the front of a b7 rs4 ?
I currently run 20" wheels ..
Here is a pic of my car for the hell of it
Re: 420mm discs
Posted: Thu Dec 07, 2017 8:08 am
by TimberTech RS4
Have a look on insta for kimboyrs4 he’s fitted 410s
Re: 420mm discs
Posted: Thu Dec 07, 2017 8:35 am
by iconic78
He had to machine down the Caliper to get it to fit under the wheel. Also some wheels won’t allow the figment. Depends on the profile.
Re: 420mm discs
Posted: Thu Dec 07, 2017 11:39 am
by dhali
OT. Have you got laminex on your headlights ??
Re: 420mm discs
Posted: Thu Dec 07, 2017 1:09 pm
by Softishman
Go big or go home!!! ;)
Re: 420mm discs
Posted: Thu Dec 07, 2017 6:25 pm
by irn_bru_ce
How much heavier are 420mm Vs OEM, can't imagine it does much for the handling
Re: 420mm discs
Posted: Thu Dec 07, 2017 7:51 pm
by Softishman
420 ceramics are lighter then oem 365 steel
Re: 420mm discs
Posted: Fri Dec 08, 2017 7:44 am
by iconic78
Here’s the thing, if your planning on running 420’s what are you doing to upgrade the master cylinder or brake booster?
If it’s just for looks then fine but you’ll never get the full potential of the disc as the cylinder can’t pump enough fluid effectively.
If it did you’d be over braking on the fronts.
Easiest way to see if they fit is to use a cardboard cutout and centre it on your hub.
Re: 420mm discs
Posted: Fri Dec 08, 2017 11:05 am
by Softishman
It has nothing to do with the discs, is the area of the pistons on the caliper. Oem is 8-piston calipers. Brembo caliper for the 400mm and the 420mm is only 6-piston but a little bigger area so the brake pedal travel is about the same. If you choose the bigger Alcons calipers for the 420mm disc they are 8-piston and the pedal travel should be a little longer for the same braking power.
Re: 420mm discs
Posted: Fri Dec 08, 2017 4:46 pm
by iconic78
Softishman wrote:It has nothing to do with the discs, is the area of the pistons on the caliper. Oem is 8-piston calipers. Brembo caliper for the 400mm and the 420mm is only 6-piston but a little bigger area so the brake pedal travel is about the same. If you choose the bigger Alcons calipers for the 420mm disc they are 8-piston and the pedal travel should be a little longer for the same braking power.
I think you misunderstood me.
Re: 420mm discs
Posted: Fri Dec 08, 2017 6:52 pm
by Softishman
I don’t think so.
