Intermitant fuel pump not priming with ignition
Posted: Mon Oct 23, 2017 6:28 pm
by Rodney007
Several times the fuel pump wont prime when switching on ignition.
If engine start is pressed it just tries to wind over. Only will leaving the car off for a few minutes seems to sort it as if it never had a problem.
Anyone come across this or know what/where I could start to look?
Cheers,
Re: Intermitant fuel pump not priming with ignition
Posted: Tue Oct 24, 2017 3:08 pm
by rs user
yes-change the fuel pump relay under ecu-there are 3 relays 2 large and one smaller-change them all while there[cheap enough]
this is becoming a fairly common problem with these cars
it could possibly be your pump itself but i would do the relays first
Posted: Tue Oct 24, 2017 4:47 pm
by Surrey Sam
arthur.d wrote: ↑Tue Oct 24, 2017 3:08 pm
Absolutely this^^^
They're a bit of a pain to change out, as the wiper arm needs to be removed, but worth doing them all to save any further hassle.
Posted: Tue Oct 24, 2017 5:34 pm
by rs user
when removing fit a new scuttle panel-get it from audi-its around £20 freshens up the area
take your time with wiper removal and careful with the screen-use tape where wipers go to aid re-fitting etc
Posted: Tue Oct 24, 2017 7:17 pm
by RS4eddie
I'm thinking about changing all relays while in there. Has anyone done this recently and have all the part numbers needed?
Looks like this is the fuel pump relay:
4H0 951 253
And I believe two are needed. (??)
I hear the updated are 644 ones:
Original ones are the 614:
Starter relay:
4H0 951 253A (??)
Any other relays I should swap in?
Thanks.
Posted: Tue Oct 24, 2017 7:27 pm
by rs user
do the little one while you are there too-silly not to-[thats the 373]
644-70 amp relay x2[meyle or similar] to replace the 614-its called a multi function relay around a tenner a throw
373 AUDI VW VAG GROUP 8D0951253A x1-this is around seven quid
Posted: Tue Oct 24, 2017 9:53 pm
by RS4eddie
arthur.d wrote:do the little one while you are there too-silly not to-[thats the 373]
Thanks I'll order that one too.
Posted: Mon Oct 30, 2017 3:48 am
by Rodney007
RS4eddie wrote: ↑Tue Oct 24, 2017 9:53 pm
Engine componant relay. I replaced my 614 with 644 and seems to be ok now.
Its the number 2 slot in the relay panel.
Posted: Mon Oct 30, 2017 10:39 am
by rs user
glad it sorted your problem out-my audi had this problem for a long while before i bought it
these throw all sorts of codes when left a while- bad earthing codes etc
Posted: Tue Nov 07, 2017 5:59 pm
by Rodney007
Not good. This morning had same issue! Pump wouldnt prime. I only replaced one of the x2 614 relays however.
The diagram I was sent from Audi didnt match mine with some of the layout.. may have been for A4?
Does anyone have a link to the RS4 relay diagram?
Posted: Tue Nov 07, 2017 6:31 pm
by Surrey Sam
Vlan One, 3rd post from the end uploaded the ETK stuff for the relays -
viewtopic.php?f=35&t=110830&start=15
Posted: Tue Mar 03, 2020 6:17 pm
by RS4JAY
Well looks like I have encountered the same problem. Went to move the car before going overseas with work & it wouldn't start. No noise from the fuel priming. Never had time to have a proper look before leaving, so have only looked on here.
Seems to be a bit of confusion between relays. Can someone confirm the correct ones and best place to purchase please? Plenty on ebay but you never know what your getting from ebay.
TIA
