Headlight Auto Leveling Unit - Front
Posted: Fri Aug 18, 2017 9:28 am
by Ellis
Long time no post. Hello all
Headlights out of range post coilover installation. Rather than bending the front leveling unit (which I've tried), I would much prefer to washer it up or similar.
Has anyone successfully done this? Most interested to know how much you had to take it up to bring headlights back into range.
Re: Headlight Auto Leveling Unit - Front
Posted: Fri Aug 18, 2017 12:41 pm
by Jezza1644
Aren't there self-adjusting screws at the top of each plastic headlight cover that you can turn to adjust the beam height?
Posted: Fri Aug 18, 2017 1:28 pm
by Ellis
Jezza1644 wrote: ↑Fri Aug 18, 2017 12:41 pm
Yes, you are quite right, they are for adjusting the headlight aim. The aim is wound right down as far as it will go however, the leveling unit is fighting against it almost.
After lowering ride height, the auto-leveling controller has gone out with its normal operating window which produces a visible and audible warning every 5 minutes or so. Most people as I understand it, bend the unit to take account of new ride height. I have bent mine but it still not within range.
See bottom left of image...
Posted: Fri Aug 18, 2017 2:29 pm
by Jezza1644
Hmmm I haven't lowered my car so haven't come across this problem before
hopefully someone else will come along and advise
Posted: Fri Sep 01, 2017 12:24 pm
by Ellis
Just a little update.
Had several failed attempts to fix this correctly. Bending, washers, nuts, etc.
A quick rummage through the fuse list and thankfully it's on its own circuit. Fuse 10 (IIRC) removed and problem solved.
Posted: Fri Sep 01, 2017 2:39 pm
by Rw@@dy
I may have a problem with this as well, did you just pull the fuse from the fuse panel?
Posted: Sat Sep 02, 2017 11:28 pm
by irn_bru_ce
Do you have the dynamic headlights, presume pulling the fuse for leveling also means the headlights won't track right and left
Posted: Sun Sep 03, 2017 10:57 am
by rickster147
I also had to pull tho fuse to get it through mot I now have
VCDS so going to try setting it up with that once it gets to darker nights
