KW V3 Coilovers...
KW V3 Coilovers...
Guys
Quick question. My drc is fine at the moment as inspecred by MRC.
But what would you guys suggest is best coilover kit for the rs4. Been told by doug that the KW v3 is closest to DRC you can get.
Whos using the Kw v3s and whats your thoughts?
Re: KW V3 Coilovers...
I had it on my old rs4. When I test drove my new one with Drc I felt a big difference. Which is why the v3's are going on mine ASAP
Previously big turbo'd mk4 golf, big turbo'd Audi A3 Quattro
Currently remapped vw caddy
& 2009 rs4 saloon, TTS supercharged, mrc mapped, miltek catback, kwv3, h&r arbs, gutted precats, ceramic brakes 610bhp
I had v3's on mine. Handled like it was on rails.
CURRENT: Montecarlo Blue Alfa Romeo Giulia Quadrifolglio, 2.9ltr bi-turbo, 510bhp
PREVIOUS: Volvo V60 Polestar, build number 149/700 worldwide - 3ltr straight 6 turbo. 350bhp remapped to 400bhp. Only one of 120 in the UK
PREVIOUS: Misano red B7 saloon, stage 2 map to 425bhp, manifold flap delete, KW V3 coilovers.
I have them & can't fault them, although i can't compare them to drc as mine were shot when i bought the car.
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift
My DRC was also leaking... but on V3s the car drives amazing, would highly recommend them.
Those with V3's, how do you feel the difference in comfort between DRC and V3's?
Those who mount kw v3 at what point have the compression?
Enviado desde mi MI 5s mediante Tapatalk
Hi guys,
I just bought my RS4 and found out that the coilovers ride too low. The previous owner put cheap KW coilovers not the V3s and now I am considering replacing them with the KW V3 or Blistein B16 PSS9 Coilover Suspension Kit. The problem is I can't find info on the maximum height adjustment of either. Does anyone know whether I can adjust these so they ride normally without my tyres rubbing all the time. I want to enjoy my car but can even throw it around corners without hearing this rubbing within the wheel arches.
Cheers and thanks in advance
Bilstein b16’s will near enough sit at stock ride hightBig Tich wrote:Hi guys,
Although mine was set lowest on the rear and front to match rears hight & no rubbing could be heard
I think the rubbbing starts once spacers are fitted
Or, go DRC and KW adjustable springs. Best of both worlds.
That’s what I did maars. Honestly wouldn’t recommend it unless you’re intent on keeping DRC even after a failure. These cars are getting old and DRC will go soon enough.
Spent nearly $1600 (AUD) buying and fitting the KW HAS and a year later I’m buying KW V3s because my DRC is gone.
b16/14 at highest height is still far lower than stock-its how i ran mine,however i ran 275/30/19 on std alloys with no rubbing[no spacers either]
i had slight rubbing on front when i fitted 20" rs5 rotors et26 with 265/30 for the month or so i had them fitted
no point in the b16 over the b14 unless you do track days and want to fiddle with the damping
Users browsing this forum: Google [Bot] and 116 guests
