Page 1 of 2
Terrible radio signal
Posted: Thu Apr 27, 2017 10:42 pm
by Jon_J
I'm determined to get to the bottom of this. It's always been bad but has got worse since I installed LED DRL's. (I'll deal with that later) I have an A4 too and it's crap in that, I had an S4 before the RS and it was crap in that also.
So...has anyone fixed this. I've read hours of threads about a split in the rubber radio amplifier in the roof by the back window.
Mine had no splits but could still be faulty I guess.
Has anyone got a good signal and willing to let me try their part in mine before I shell out a couple of hundred to see if it fixes it?
Anyone got any suggestions to fix this?
Re: Terrible radio signal
Posted: Fri Apr 28, 2017 7:20 am
by rickster147
Mines same since fitting drl
Posted: Fri Apr 28, 2017 7:48 am
by Jon_J
Strange. Like I said I deal with that later. Happy to remove them for now, fix this signal issue and then install them again to see what happens.
So anyone got a good radio signal or replaced their antenna?
Posted: Fri Apr 28, 2017 10:06 am
by Trups
These mine guys?
Trups
by Trups
I know Ricksters are. need someone with my kit to try something.
Posted: Fri Apr 28, 2017 10:11 am
by Jon_J
Trups wrote:These mine guys?
Trups
Yes they are yours. Happy to help. I'm the one emailing you at the moment if you hadn't connected the two.
Posted: Fri Apr 28, 2017 10:31 am
by Trups
I didn't lol.
Posted: Fri Apr 28, 2017 10:35 am
by Jon_J
Trups wrote:I didn't lol.
Ok. So happy to help once it's sorted.
Posted: Fri Apr 28, 2017 11:46 am
by Starry
I hadn't connected the two, but mine is worse now then ever after fitting Turps's led's. I'll keep an eye on this thread...
Posted: Fri Apr 28, 2017 12:29 pm
by rickster147
Yes trups not all the time but if I pull up when it's crackling if I turn the drl off the quality is better then if turn on it goes back to bad again
I haven't fitted the beefed up cancellers yet BTW
The only time I get an error is when I start the car work the drl off
But 90 percent of the time drl is on when I start there car anyway so don't get any errors this way
Posted: Fri Apr 28, 2017 9:34 pm
by Trups
The cancellers wont stop the radio interference, the cancellers are for the error system but as you say its only when your drls are off on start up which will sort that.
As this wasn't a report on Batch 1 I need to try a few things as when you go on sidelight mode I take it its back to normal?
I need the info so I can relay back to the factory but am trying a few things this week to see if it helps as the jist of it is that as standard it was fine but not great, with my DRL kit it wipes it out.?
Posted: Fri Apr 28, 2017 10:00 pm
by Jon_J
Trups wrote:The cancellers wont stop the radio interference, the cancellers are for the error system but as you say its only when your drls are off on start up which will sort that.
I'm happy to help with this. Let's get back to 'normal' and I'll work with you on this.
Posted: Sat Apr 29, 2017 8:53 am
by rickster147
It's same on drl and side light and full lights
Only good reception when all off
Posted: Sun May 07, 2017 7:58 am
by Jon_J
So we have established the signal is worse with the DRL on. I'd still like to get to a descent signal pre DRLs.
Does anyone have a good radio signal (FM) or does it keep loosing signal, if you click off that station and back again it is good for a bit and then goes back to being crackly?
Posted: Sun May 07, 2017 12:02 pm
by dougle_turbo
Jon_J wrote: ↑Sun May 07, 2017 7:58 am
My radio signal is good, happy to help if I can. Where are you located?
I've suffered from bad radio signal in various cars over the past and the culprit has always been something drawing power that wasn't installed on the car in the factory. i.e something plugged into a cig lighter, or an amplifier etc etc.
