Oil leak
Posted: Sun Apr 09, 2017 1:40 pm
by harding
Something is leaking from the forward right side of the car. Checked the oil cooler pipes from under the car and they looked in perfect condition. I talked to an audi mechanic aswell and since the oil is rather transparent/yellow-ish and not dark/black its probably not the oil cooler pipes.
What else is up there that might leak oil?
Re: Oil leak
Posted: Sun Apr 09, 2017 1:51 pm
by daytonamart
Aux rads?
Re: Oil leak
Posted: Sun Apr 09, 2017 2:14 pm
by Stew
I no this might not b for everyone but taste it if it if its a sweet taste its coolant if not it could be dog piss like what happened me a few years back
Re: Oil leak
Posted: Sun Apr 09, 2017 3:57 pm
by Grandadg90
Oil cooler pipes, looks block end.
Re: Oil leak
Posted: Wed Apr 12, 2017 7:51 pm
by Audi Pardner
Grandadg90 wrote: ↑Sun Apr 09, 2017 3:57 pm
Could well be. Failed 'O' ring possibly.
Re: Oil leak
Posted: Wed Apr 12, 2017 10:52 pm
by Grandadg90
If it is, the o-rings are about £25 each from Audi. You will most likely need two. However you may have an issue with your actual pipes as sometimes they rub together which causes them to wear away at the braiding which causes them to split. There was a recall on these pipes due to this from Audi . However your oil drops seem to be minimal so I would lean towards the o-rings.
Hope that helps.
