What a total clutch!!
Re: What a total clutch!!
Whatever you do make sure you get rob Nicholsons upgraded return pipe to stop the sticky pedal problem
Don't suppose you could share any parts and part numbers from TPS/Audi could you of the little fiddly stuff from Audi/TPS please?
I'll start the list of everything req:
LUK DMF077
http://www.rockauto.com/en/moreinfo.php ... 342&jpid=0
MMAIL6 knocks 5% off
LUK Clutch Kit
http://www.carparts4less.co.uk/search/641442580
SPRING10 knocks 10% off
Robnic Modified Hose
PM him, ever so helpful and decent part
memberlist.php?mode=viewprofile&u=34106
I'll have to go through my receipts for the clutch hose/slave seals and manifold nuts/studs.
LUK DMF077
LUK Clutch Kit
eliano wrote: ↑Thu Mar 23, 2017 7:25 amI just paid about £1200 all in for mine, that was....
Luk clutch (euros), luk flywheel (rock usa), sachs slave (euros), robnic pipe, robnic also sold me all the levers and bolts etc (all from audi/tps), millers gearbox oil/ diff oil (ebay) , also crank sensor broke during job and my mate fitted it all for £230 it would have been less but 4 out of 6 exhaust manifold bolts snapped and had to be drilled out and replaced (added an hour or two).parts came in about a grand. It pays to Shop about and use discoumt codes etc.
That said the flywheel in the uk is always around the £800 mark alone (same part as from usa)
You need to factor the fw into the job, everyone told me not to bother but i saw it myself when it came out and was scrap metal , the famous sticky pedal ate my clutch and fw quite quickly.
so if that price of £1500-£2000 youve been quoted is for all the work and all the bits you need to change then its not really that bad a price, as you said its the labour cost that hikes it up quite dramatically. The parts themselves are quite reasonable (if you Shop about) considering the usual RS tax we pay on parts
Theres 30% of at eurocarparts for the clutch and slave, rockauto for the fw and robnic will sell you all the genuine bits,bolts, pipes, levers etc at cost as well. Drop him an inbox
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
Ok cheers, the clutch works out cheaper (today at least) on CP4L even though it's the same company as ECP
I surprised that UNit20 were more than MRC, perhaps that's why Grizz won't tell me how much my cambelt service is going to be
You can't get the LUK in Europe, wouldn't blame them for that. They have better things to do than source things on the other side of the pond I imagine...
If I were you I would consider using the single mass flywheel offered on Ebay (billet flywheel made in the UK) that is both cheaper and lighter. Works with OEM standard clutch.
I rather like mine, there is some chatter in gear at very low revs (near idle) which is not particularly dramatic and easily avoided if you don't lug the engine.
edit: http://ttvracing.com/product/audi-rs4-4-2-v8-b7-06-08/ (about 350 quid I believe I paid)
981 Cayman GTS Gray/Orange.
My youtube
My youtube
- Robnic
Hi,
Thanks for the recommendations, as some of you know I run a Bosch Car Service garage in Lincolnshire between Scunthorpe & Doncaster, I have done work, sold parts - including our modified clutch pipe, even sold a car to RS246 members, we charge £49.50 / Hr + vat, the clutch job and associated components takes around 6.5 to 7 hours to do, normally the exhaust manifold studs - unless they have been changed previously, can be severly corroded so you can add between one to two hours to remove and fit new (we use an inductive heater so no naked flame under the car!)
Same as carbon cleaning we walnut shell blast with the total job coming in around 6 hours with pair new manifold gaskets and a couple of seals so not too bad really.
The garage website is here as with most not fully up to date but you get the jist; www.nicholsonmotors.co.uk
As far as fitting customer supplied parts there is a national push to stop this (a lot haven't done this for some time) it is being driven by our insurers as our liability insurance does not stand if we have no 'paper trail' for parts purchased, obviously we can supply all the parts genuine and / or OE equivalent. That being said for a fellow RS owner if you rock up (pun intended) with a Rockauto DMF I would fit it whilst doing the job although this would have been discussed before the job was booked in.
Rob
Rob
B7 RS4 MTM K540 Sprint loon, Lysholm/Opcon twin-screw supercharger, Ceramics, HEL Hoses, Loba SM Fly, Sachs performance clutch kit, MTM full stainless exhaust system with freeflow cats & quad valved tailpipes, Hotchkis ARB's, Bilstein B16 Coil Overs, LED Rear lights, Interior & LED 50W DRL's, Buckets in race cloth, Black optics, FBSW, Titanium pack, Solar Sunroof, Adaptive lights, MTM 10mm spacers Fr & Rr, 193 Nav unit, 2nd careful owner
I have a feeling my clutch will need doing soon too..
Called Audi...£1000 for a clutch including fitting...due to the age of the car..and £1000 for a flywheel (part only) fitting is included for free.
Aren't RS models usually excluded from the fixed price arrangements?
[/quote]
There are separate fixed prices for RS models.
[/quote]
Toy: '07 B7 RS4 Avant Sprint Blue
Daily: 06 B7 2.0T Special Edition Avant
Previous: '09 B8 2.0T Quattro S line Avant
- OEM Defined - Instagram: @OEMDefined - Facebook: https://www.facebook.com/OemDefined/ -
i have just done this myself. all the studs broke in the exhaust manifold . gearbox oil and diff oil was £100 from tps
Just lifted my car from the mechanics and I have my old clutch here, this is the original clutch, removed at 70k, as you can see it is stamped vw Audi but is made by luk hopefully this clears things up men
- 2nd Gear
So has anybody successfully fitted the metal slave cylinder thats available in the states, is it worth swapping out the master and slave cylinders while doing the job?
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Users browsing this forum: No registered users and 569 guests
