Rs4 b7 wheel fitment thread
Posted: Fri Feb 03, 2017 5:45 pm
by chriswhite1992
After searching i can believe no one has made a proper thread for wheel fitment on the rs4 so im going to make one!
Post up you pictures on here.
Wheels and Offset
Spacer Size
Tire Size and Make
Suspension Setup
Camber Settings
Toe Settings
Hopefully this will help people decide on what size wheels to buy
Just for people who don't know
Standard rs4 alloys are 19x9j et29
Re: Rs4 b7 wheel fitment thread
Posted: Sun Feb 05, 2017 7:00 am
by MartayMcFly
Wheels and Offset - Audi Q7, 20x9J ET60
Spacer Size - 35mm pcd adapter
Tire Size and Make - 255/30R20 Michelin PSS
Suspension Setup - DRC with KW adjustable springs (approx 25mm lowered)
Posted: Sun Feb 05, 2017 7:06 am
by MartayMcFly
Wheels and Offset - Audi RS5 Rotors, 20x9" ET26
Spacer Size - None
Tire Size and Make - 245/35R20 Toyo Proxes
Suspension Setup - KW V3 coilovers
Posted: Sun Feb 05, 2017 7:11 am
by MartayMcFly
Wheels and Offset - Rotiform SNA, 19x10J ET35
Spacer Size - None
Tire Size and Make - 265/30R19 Michelin PSS
Posted: Sun Feb 05, 2017 9:01 am
by chriswhite1992
I think the rs5 rotors suit the b7 so well
Posted: Mon Jul 24, 2017 6:50 pm
by suurenmoinen
Question: would 9.5x19 5x112 ET25 OZ Ultraleggeras HLT fit? (Michelin PSS 265/35/19)
Posted: Wed Jul 26, 2017 11:45 am
by suurenmoinen
According to this: http://www.willtheyfit.com/?aspect=35&a ... width2=265
"Compared to your existing wheel, this new wheel will have an inner rim which is 2.3mm closer to the suspension strut. The outer rim will poke out 10.4mm more than before."
Which should be fine...at the moment I am running 10x19 ET20 with minimum rubbing in the font under full suspension compression.
Any thoughts?
Posted: Tue Aug 01, 2017 8:47 am
by suurenmoinen
Any thoughts?
:boots:
Posted: Wed Oct 25, 2017 7:50 pm
by famguy
Does someone know if the Niche Form wheels in 20x10.5" ET27 will clear the brakes?
