Page 1 of 2
Adjusting rear bilstein coilovers
Posted: Sun Jan 01, 2017 6:51 pm
by Frostie
Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
Re: Adjusting rear bilstein coilovers
Posted: Sun Jan 01, 2017 6:53 pm
by pule333
Frostie wrote:Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
Yes! Blood, sweat, and tears....
and plenty of swearing
Posted: Sun Jan 01, 2017 6:54 pm
by Frostie
pule333 wrote:Frostie wrote:Is there any easy way to adjust the ride height of the bilstein rear coilovers without dropping the whole rear arm...
Chris
Just as i feared...
Posted: Sun Jan 01, 2017 7:21 pm
by pule333
B14 or B16??? Need plenty of lube on the treads. Had to slightly modify the keys supplied to be able to use with 20mm wrench as extension...
Posted: Sun Jan 01, 2017 7:23 pm
by Frostie
B14... Just the basic ones.
Posted: Sun Jan 01, 2017 7:24 pm
by pule333
That's all you need on the Rs4 trust me
best setting anyways.
Posted: Sun Jan 01, 2017 7:25 pm
by Frostie
It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
Posted: Sun Jan 01, 2017 7:28 pm
by pule333
Frostie wrote:It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
Hence why you need extra leverage and more lube
Posted: Sun Jan 01, 2017 7:30 pm
by Frostie
pule333 wrote:Frostie wrote:It seems that when trying to adjust with the spanners, there is too much pressure on the spring to allow the thread to move...
Thanks lol
Posted: Sun Jan 01, 2017 7:53 pm
by BenHol
It's a pig of a job. Instead of dropping the sub frame. I drilled a small hole straight through the threaded spring holder and welded a long thin metal tool to slide in and hold it in position. Then a lot of patience doing little quarter turns.
Posted: Sun Jan 01, 2017 7:55 pm
by BenHol
Just realised that didn't sound right. I made a removable tool and didn't weld anything to the spring seat or thread.
Posted: Sun Jan 01, 2017 7:56 pm
by Frostie
Thanks for the info
Posted: Sun Jan 01, 2017 11:42 pm
by Starry
I'm looking to install my b14's in the next week or so. Judging by this thread the rears are a pita so I'm hoping to get them set to the right hight before fitting them.
I want to run it pretty low, does anyone know where i should be looking to set them? Also, how much will they settle once fitted?
Posted: Mon Jan 02, 2017 12:41 am
by Frostie
I'll have a look where mine are tomorrow and let you know.
Posted: Mon Jan 02, 2017 7:32 am
by Starry
Frostie wrote:I'll have a look where mine are tomorrow and let you know.
Thanks Frostie....
