RNS-E - fitted Bluetooth now have whine through speakers?
Posted: Mon Nov 14, 2016 10:15 am
by electricfurnace
Fitted a genuine Audi bluetooth kit to my RNS-E in my B7 RS4.
Works fine but I now have a whine through the speakers which increases on accelerating?
Any ideas? Harness was plug and play. Sounds like a grounding issue?
Re: RNS-E - fitted Bluetooth now have whine through speakers
Posted: Mon Nov 14, 2016 2:20 pm
by harding
electricfurnace wrote: Pulled out stereo, located brown bose wire in pin 7 in green connector in quadlock.
Pulled out wire and grounded it a screw on back of head unit.
Something tells me this has something to do with it...
Posted: Mon Nov 14, 2016 5:38 pm
by obikaii
I had this a while ago & it was the amp that was causing the whine,try disconnecting it.
I disconnected mine & was gonna get a new one,but when I reconnected it the whine was gone,but it does come back from time to time.
Posted: Mon Nov 14, 2016 5:45 pm
by electricfurnace
Dont think so as before i fitted the bluetooth but after doing the bose mod it was fine?
by electricfurnace
obikaii wrote:I had this a while ago & it was the amp that was causing the whine,try disconnecting it.
How do you disconnect the amp mate?
Posted: Mon Nov 14, 2016 8:38 pm
by MikeFish
Can you undo the bose mod?
Posted: Tue Nov 15, 2016 12:11 am
by electricfurnace
Yep just undone the bose mod, still whining
Posted: Wed Nov 16, 2016 12:35 am
by electricfurnace
Still whining! Really odd. Bluetooth harness issue maybe?
Posted: Thu Nov 17, 2016 6:53 pm
by obikaii
You can unplug the amp from the boot,its behind a removable pannel,drivers side,the lead has a red clamp that you need to unclip.
