EPC Light
Posted: Fri Sep 16, 2016 3:42 am
by scotty493
Hi started my car this morning and the EPC light stayed on and the car had a misfire,have any of you had this problem and what was it? Or what could it be?
Mike
Re: EPC Light
Posted: Fri Sep 16, 2016 7:56 am
by The_Coat
Need to scan the car for the error code really or its all just guess work.
Could be a coil pack?
Re: EPC Light
Posted: Fri Sep 16, 2016 10:45 am
by scotty493
I read somewhere on google you can buy a diagnostic tool fairly cheap for audis is this true do you know?
Re: EPC Light
Posted: Fri Sep 16, 2016 4:58 pm
by Markwes
Get one of these and download the app 'Torque' from the google play store. Allows you to read the fault codes and also reset them if you want.
Re: EPC Light
Posted: Fri Sep 16, 2016 5:04 pm
by roadrunner143
Mine is doing it now once in a while. EPC light on when driving aound town after a while. No misfire. Code is for intake manifold flap.
The misfire and EPC could be unrelated. As stated above have the codes checked out. I use this for a quick check: http://gopointtech.com/product/bt1-for-apple/
Re: EPC Light
Posted: Sat Sep 17, 2016 2:37 pm
by scotty493
Markwes wrote:Get one of these and download the app 'Torque' from the google play store. Allows you to read the fault codes and also reset them if you want.
And these work ok yeah?
Re: EPC Light
Posted: Sat Sep 17, 2016 3:06 pm
by harding
Mine has this aswell from time to time. No misfire tho..
Re: EPC Light
Posted: Sat Sep 17, 2016 5:57 pm
by Markwes
Yes they do the job and are cheap.
Re: EPC Light
Posted: Sat Sep 17, 2016 6:08 pm
by EddyPee
Mine has thrown an EPC light, had the Audi assist out to it and diagnosed sticking Intake flaps. I'd had this several times before and it had always been duff coil packs.
He suggested it will likely need an intake Manifold replacement which hopefully I can get done under warranty.
Power and drive seems ok, no misfire, maybe slightly lumpy but having given it some beans on the way home the light cleared for a bit then came back on and has cleared again.
Will put it in next week. Anyone know the rough cost for the work?
Re: EPC Light
Posted: Sun Sep 18, 2016 7:07 pm
by mustdash
Or you could go to MRC and get a manifold flap delete and stage 2 for less than a new manifold would cost....
