Gruppe m throttle hesitation
Posted: Fri Jun 17, 2016 8:22 am
by callumjones
I fitted my gruppe m carbon airbox last night and took it for a quick blast to see what its like and absolutely loved it.
However i noticed that after a fast gear change the car was slightly hesitant, like a loss of power for a second and then returns to normal.
There is no cel so nothing to indicate that it is fitted incorrectly and i have positioned the MAF at a similar angle to the standard airbox.
Can anyone shed some light on this?
Thanks in advance
Callum
Re: Gruppe m throttle hesitation
Posted: Fri Jun 17, 2016 9:44 am
by Wavey Dynamicist
Is it just going into gears 2 and 3? If so, disable traction control and see how you get on.
It's quite a crude system in a sense, it seems to cut power in anticipation of slip on WOT high engine speed gear changes from 1 to 2 and 2 to 3.
Posted: Fri Jun 17, 2016 10:04 am
by Surrey Sam
As above, I drove around for best part of a year thinking that the hesitation was some kind of torque limiter, as you dont see any traction control light flashing. However turn the system off fully and the hesitation dissapears.
Posted: Fri Jun 17, 2016 10:17 am
by TonyHayers
Jaheenormous wrote:Is it just going into gears 2 and 3? If so, disable traction control and see how you get on.
Yeah. I've had it a few times when pushing it in lower gears, just cuts totally cuts power.
Posted: Thu Jun 23, 2016 11:18 am
by irishmike
Interesting!
I've had that at times and thought something was amiss, good to know.
