Page 1 of 4
Odd starter issue
Posted: Fri May 13, 2016 3:04 pm
by irishmike
Following on from my previous Battery issue I am still having issues starting the car on occasion
I've changed the battery twice now, first time was actually a dodgy battery contributing to the issue.
However now I know the battery is fine and I'm still having issues.
Symptoms are as follows:
Car starts perfect when cold - every time
When properly warm, driving for 30mins plus, if I stop it may not start. Does not turn over, just a slight click when the button is pressed
Leave it for 10 mins and starts fine
Scan shows the below:
01 Engine Control Module 1
System description: 4.2L V8/4V FSI ª
Software version: 0090
Hardware number: 8E1910560
Long coding: 01040003180F0160
Trouble codes:
P3088 - Starter relay Electrical error in circuit Upper limit exceeded
Intermittent
Any ideas?
Re: Odd starter issue
Posted: Fri May 13, 2016 4:11 pm
by CaptainLeadFoot
your starter relay is stuffed from the code, literally.
Posted: Fri May 13, 2016 4:16 pm
by andyg72
I replaced both starter relays there about £30 each
And clutch switch £15
Then starter motor £385
Posted: Fri May 13, 2016 4:31 pm
by irishmike
Was it a similar issue?
Posted: Fri May 13, 2016 4:32 pm
by irishmike
CaptainLeadFoot wrote:your starter relay is stuffed from the code, literally.
Would that not act up when cold too?
Posted: Fri May 13, 2016 6:36 pm
by CaptainLeadFoot
irishmike wrote:CaptainLeadFoot wrote:your starter relay is stuffed from the code, literally.
This could be the relay is not discharing properly when you have warm start, which never is an issue with cold start because the charge would have been depleted
Posted: Sat May 14, 2016 5:45 am
by andyg72
irishmike wrote:Was it a similar issue?
Yes a very similar issue mike
I can remember the exact vagcom code but was pointing to the relay that's why they were replaced ultimately it was the starter motor .
Posted: Sat May 14, 2016 10:51 am
by r5ccu
Same issue I had both relays changed then starter and all was fine
Posted: Sat May 14, 2016 12:28 pm
by irishmike
Cheers guys
Audi got back to me on the prices.
325 for the starter and 7 hours to fit it!
Seems excessive...
Posted: Sat May 14, 2016 12:34 pm
by MikeFish
I think I said this in the other thrread, my old fiat coupe was exactly the same. The starter solenoid would jam when hot so it clicks but as the solenoid didn't fully extend it didn't turn the engine. Wait until it cools then its all fine. Changed starter motor; all good.
Posted: Sat May 14, 2016 12:35 pm
by MikeFish
Starter from ECP was about £142 I think. Then labour to fit.
Posted: Sat May 14, 2016 1:02 pm
by irishmike
How long did it take do you remember?
Posted: Sat May 14, 2016 6:53 pm
by MikeFish
It's going in to be done next week. It's having a load of other work done at the same time too like the engine mount that sits under the starter motor so probably won't know the exact time.
Posted: Sat May 14, 2016 8:26 pm
by irishmike
Ah ok, cheers.
Posted: Sat May 14, 2016 8:28 pm
by andyg72
I had my starter motor fitted at midland Vw genuine Audi starter and took 3 hours to fit
