Inlet Manifold Flaps
Posted: Sat Apr 09, 2016 8:36 pm
by kevconn
Hi all,
Had the RS4 for about 6 weeks now and took if for a service today and was advised that when they checked on the
Vagcom it indicated that one of my manifold flaps was stuck open?
With knowing nothing at all about this subject I asked what it meant. I was told that if all the valves are open I wouldn't be able to accelerate but this made no sense to me.
Can somebody please advise what thus means, what causes it, how can it be rectified and costs involved?
Posted: Sat Apr 09, 2016 9:48 pm
by Seattle-squash
They have a tendency to get stuck, especially with lots of carbon around and or a shaft bushing or flap positioning sensor being off (you have 2). What I did - carbon cleaned, and coded out the flap error message and good to go. If you have issues mechanically the the either new manifold or pull them and get covered by the re-coding. So if I pull mine in the future I should still have no dash/code issue. I think they are supposed to increase torque with added turbulence but what the heck do I know!
I hear that people pull them often with little to no feeling of lost torque. Have your car been carbon cleaned? If not, I would look into that. Good luck.
Re: Inlet Manifold Flaps
Posted: Sat Apr 09, 2016 9:51 pm
by TAB1S
Hi mate it's not an uncommon problem, I've just sorted mine out.
Unfortunately it's not an quick fix, they stick open or closed due to carbon build up on the inlet manifold so you are in need of a carbon clean (decoke) research it buddy there's lots of threads on how to etc etc or go to MRC but it will cost you, quite a few people do it them selfs if you are half about with tools & have a fair bit of time on your hands.
You can either keep the flaps or remove them as i have to hopefully help prevent build up so fast & again hoping for performance gains
but will then required a remap to delete the flap sensors.
You will also be down on power as it will put your car in a mild limp mode ie you wont have full rev range!
Good luck hope this helps, good luck.
Posted: Sat Apr 09, 2016 9:53 pm
by Seattle-squash
TAB1S wrote:Hi mate it's not an uncommon problem, I've just sorted mine out.
It must be a common problem - with both of us stating the same thing!
Posted: Sun Apr 10, 2016 12:34 pm
by kevconn
Thanks for the info, I'm in Lancashire so is there anybody localish that could do the clean, how much would it be and how long of a job is it?
Posted: Sun Apr 10, 2016 12:41 pm
by TAB1S
kevconn wrote:Thanks for the info, I'm in Lancashire so is there anybody localish that could do the clean, how much would it be and how long of a job is it?
Yes mate unit20 are close to you, mrc are about£600 for a basic clean going up to £1100 for a deflap etc look on there web sites mate.
Posted: Sun Apr 10, 2016 7:35 pm
by mustdash
Mine was throwing up an engine management light -
Vagcom showed a manifold flap issue. I took it to MRC for a decoke and to have the flap removed then a map to map out the sensor. THe fault didn't cause any noticeable issues with the car, other than a permanetly lit engine warning light (not good for the MOT).
Posted: Sun Apr 10, 2016 8:55 pm
by kevconn
Gonna do a bit of ringing around tomorrow so I have a better understanding of what's going on. Don't really want to be deleting flaps and remapping. I more bothered about how long the job takes as I use car every day.
Posted: Fri Apr 15, 2016 5:02 pm
by pablos007
Had mine done at Awesome GTI in Manchester last year, and it gave me around 80bhp back! The difference was night and day!
Posted: Tue Aug 21, 2018 3:13 pm
by RS4JAY
What did you do in the end mate?
Hijacking every manifold thread lol
Posted: Tue Aug 21, 2018 9:40 pm
by jordanbutters
I had my inlet flaps removed and mapped out by Regal. They did a stellar job and, along with a carbon clean, when from 380hp to 420hp.
Posted: Tue Aug 21, 2018 9:54 pm
by RS4JAY
jordanbutters wrote: ↑Tue Aug 21, 2018 9:40 pm
What did it cost in the end mate ?
Posted: Sun Aug 26, 2018 12:47 pm
by jordanbutters
I can’t remember now as I had a load of other work done too. Give Regal Autosport a call and mention that Jordan recommended them and they’ll quote you over the phone.
