Parking sensor display
Posted: Sat Feb 20, 2016 10:56 pm
by chuckrs4
I know on some of the newer audis you get a display come on the navi system for the park sensors. Is it possible to set it up on the rs4? Cheers
Re: Parking sensor display
Posted: Sun Feb 21, 2016 12:28 am
by bigrichw
I think you would need the mk2 rns-E to start with.
Posted: Sun Feb 21, 2016 9:39 am
by chuckrs4
Ahh, wasn't sure if there was much different in the head units as the look the same but never mind. Cheers
Posted: Sun Feb 21, 2016 5:46 pm
by PetrolDave
bigrichw wrote:I think you would need the mk2 rns-E to start with.
Not even possible with the Mk2 RNS-E.
The "CAR" button on the RNS-E is a complete joke...
Posted: Sun Feb 21, 2016 7:47 pm
by chuckrs4
not as simple as a different coding then?haha
Posted: Mon Feb 22, 2016 7:03 pm
by PetrolDave
chuckrs4 wrote:not as simple as a different coding then?haha
Nope, sadly not.
Posted: Mon Feb 22, 2016 7:18 pm
by bigrichw
I had this on my 09 S3, and miss it in my RS4. Shame it's not a simple mod.
Posted: Mon Feb 22, 2016 7:26 pm
by PetrolDave
bigrichw wrote:I had this on my 09 S3, and miss it in my RS4. Shame it's not a simple mod.
It's for the same reason that the speed limit display doesn't work on the Mk2 RNS-E - the data simply isn't passed onto the Infotainment CAN bus on the B7.
Posted: Mon Feb 22, 2016 10:40 pm
by chuckrs4
How about updates for the rns-e. Is it just a case of getting a new disc for 7 digit postcodes or is it a new unit again? If it is what would be the best type unit to go for or does that code a fortune?
Posted: Tue Feb 23, 2016 6:57 pm
by PetrolDave
chuckrs4 wrote:How about updates for the rns-e. Is it just a case of getting a new disc for 7 digit postcodes or is it a new unit again? If it is what would be the best type unit to go for or does that code a fortune?
7 digit postcodes are not available with a genuine Audi DVD, only with a DVD (not a pressed one but a burnt one) from a third-party. Personally I won't let a copied DVD anywhere near my RNS-E (as a Moderator on audiforum.us I've seen far too many cases of lasers failing after use of copied DVDs).
If you want a Mk2 RNS-E then you need either an A3 or TT one fitted with an A4 faceplate.
