Page 1 of 4
Vibrating on Full Lock
Posted: Sun Feb 07, 2016 9:26 am
by norman1979
I recently purchased an avant with SS+ and I have noticed that on full lock I get a vibrating sound which sort of shakes the car.
It happens on full lock left or right. Is this a characteristic of the car? Or something untoward that needs looking into?
Re: Vibrating on Full Lock
Posted: Sun Feb 07, 2016 11:22 am
by chunky79
Only at low speeds?
Posted: Sun Feb 07, 2016 11:33 am
by norman1979
Yes low speeds. Also I feel it on tight left or right turns at very low speed
Posted: Sun Feb 07, 2016 11:34 am
by Surrey Sam
Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
Posted: Sun Feb 07, 2016 11:39 am
by chunky79
Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
This ^^^^^. This is normal.
Posted: Sun Feb 07, 2016 12:01 pm
by Surrey Sam
chunky79 wrote:Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
Although it does become more prominent, when the tyre tread depths are low and/or toe alignment out of spec.
Posted: Sun Feb 07, 2016 12:02 pm
by PetrolDave
+1
It's worse on tyres that are more than half worn or in cold temperatures too.
Posted: Sun Feb 07, 2016 12:06 pm
by norman1979
Yes thats it. I feel it throughout the car though not just from the front. Is that normal? Its abitstrange for it to be normal
Posted: Sun Feb 07, 2016 12:15 pm
by chunky79
norman1979 wrote:Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
Get someone to drive it while you're in the boot. See if you can feel it while in there.
Posted: Sun Feb 07, 2016 12:34 pm
by eliano
Hi. New member (well contributing) ,ive been reading the forum a few weeks now. I will do the intro later if thats ok..... anyway i get this same issue, a few times now ive turned off drive etc and i think i have a flat, strange sensation that has me out the car to check , feels like a flat or like tyres rubbing the arch, it is neither but id be glad to hear if this is normal , car has ss+ if that makes a differance? cheers
Posted: Sun Feb 07, 2016 1:05 pm
by Harris.
Mine did this when coming off my drive. A weird feeling but I've had 4 wheel hunter alignment last week and since then It's stopped.
Posted: Sun Feb 07, 2016 1:16 pm
by norman1979
Would it be worse with SS+?
Posted: Sun Feb 07, 2016 1:37 pm
by Harris.
I wouldn't have thought so . Take the car and have the tracking etc checked
Posted: Sun Feb 07, 2016 5:36 pm
by Simon the sparky
I would agree with others that it is normal, but made more noticeable if the tyre treads are low.
I bought my b7 avant a few weeks ago, and the feeling/vibration was quite bad, but as I wasn't happy with the Dunlop tyres that were on it, I've just had a set of Michelin pilot 3s fitted, and it's hardly noticeable now.
Posted: Sun Feb 07, 2016 8:42 pm
by Baz999
I have this and my tread is 4mm. Use to have this also in my Scrooby when the tyres would get low. I put it down to the tyres and the 4wd system
