Vibrating on Full Lock
- 2nd Gear
I recently purchased an avant with SS+ and I have noticed that on full lock I get a vibrating sound which sort of shakes the car.
It happens on full lock left or right. Is this a characteristic of the car? Or something untoward that needs looking into?
Re: Vibrating on Full Lock
Only at low speeds?
- 2nd Gear
Yes low speeds. Also I feel it on tight left or right turns at very low speed
- Surrey Sam
Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
This ^^^^^. This is normal.Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
- Surrey Sam
Although it does become more prominent, when the tyre tread depths are low and/or toe alignment out of spec.chunky79 wrote:This ^^^^^. This is normal.Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
- PetrolDave
+1chunky79 wrote:This ^^^^^. This is normal.Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
It's worse on tyres that are more than half worn or in cold temperatures too.
- 2nd Gear
Yes thats it. I feel it throughout the car though not just from the front. Is that normal? Its abitstrange for it to be normal
Get someone to drive it while you're in the boot. See if you can feel it while in there.norman1979 wrote:Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
Hi. New member (well contributing) ,ive been reading the forum a few weeks now. I will do the intro later if thats ok..... anyway i get this same issue, a few times now ive turned off drive etc and i think i have a flat, strange sensation that has me out the car to check , feels like a flat or like tyres rubbing the arch, it is neither but id be glad to hear if this is normal , car has ss+ if that makes a differance? cheers
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
Mine did this when coming off my drive. A weird feeling but I've had 4 wheel hunter alignment last week and since then It's stopped.
- 2nd Gear
Would it be worse with SS+?
I wouldn't have thought so . Take the car and have the tracking etc checked
- Simon the sparky
I would agree with others that it is normal, but made more noticeable if the tyre treads are low.
I bought my b7 avant a few weeks ago, and the feeling/vibration was quite bad, but as I wasn't happy with the Dunlop tyres that were on it, I've just had a set of Michelin pilot 3s fitted, and it's hardly noticeable now.
Current: RS4 Avant B7, Range Rover 4.4, VW up!, Fiesta ST van.
Previous: A3, S3, A6 Allroad, UR quattro, Porsche 3.2, Skyline R33 GTR,
Subaru WRX,
Subaru WRX,
I have this and my tread is 4mm. Use to have this also in my Scrooby when the tyres would get low. I put it down to the tyres and the 4wd system
