Rear heated screen problem
Posted: Sun Jan 24, 2016 4:11 pm
by BiebaRS4
Afternoon gents,
My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
Thanks in advance,
Matt
Re: Rear heated screen problem
Posted: Sun Jan 24, 2016 4:39 pm
by PetrolDave
BiebaRS4 wrote:My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
The heated rear screen is also used as one of the aerials for the radio.
To avoid interference on the radio there is a filter in series with the feed to the heated rear screen that separates the power from the aerial signal, I suspect that may be your problem - it's a not uncommon fault on Audis.
Posted: Sun Jan 24, 2016 5:05 pm
by RSCosworth
PetrolDave wrote:BiebaRS4 wrote:My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think??
Posted: Sun Jan 24, 2016 5:23 pm
by PetrolDave
RSCosworth wrote:Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think??
Sounds like the likely culprit.
IIRC it's behind the trim above the rear window on the saloon, and behind the rear side trim (can't remember if it's LHS or RHS) on the Avant.
Posted: Sun Jan 24, 2016 5:29 pm
by RSCosworth
Nice one cheers buddy, will check it out
