Ok to drive with SAI insufficient flow error code?
Posted: Wed Dec 30, 2015 8:23 am
by Xiulaba
I am getting a P0491-002 SAI insufficient flow on Bank 1. As it is more for emmission control would it be ok to continue driving? I got the codes off a borrowed
VCDS, waiting for delivery on mine so unable to perform tests yet. Thanks!
Re: Ok to drive with SAI insufficient flow error code?
Posted: Wed Dec 30, 2015 9:31 pm
by Grandadg90
You will most likely have a vacuum leak. Will be ok to drive.
Posted: Sat Jan 02, 2016 11:49 am
by Xiulaba
Grandadg90 wrote:You will most likely have a vacuum leak. Will be ok to drive.
Thanks Grandadg90. Best not to drive the girl around until the issue's sorted but just can't resist giving her a blast now and.then!
Posted: Wed Jan 06, 2016 1:02 pm
by Wotsirb
Xiulaba wrote:Grandadg90 wrote:You will most likely have a vacuum leak. Will be ok to drive.
I have the same error code and an engine management light.
The SAI pre heats the Cats on cold start for around 1/3 minutes. Then switches off. A lot of people on here with an MRC map have had the SAI removed.
Talk about a pointless waste of material. You'll be fine to drive, just make sure she's warm before driving away... Which you should do anyway, right? Lol
Posted: Wed Jan 06, 2016 6:25 pm
by Xiulaba
Searched on the forum and read that MRC doesn't do remote maps. JHM Could but would required piggies at the least. Any idea whether APR maps can map out the fault codes/warning lights after SAI removal?
Posted: Wed Jan 06, 2016 7:08 pm
by marc1
Where are you based?
Posted: Thu Jan 07, 2016 2:06 pm
by Xiulaba
Malaysia. I am near singapore if there are any workshops available there as well
