Page 1 of 2
Help! suspected coolant leaking - Pic
Posted: Sat Nov 28, 2015 4:11 pm
by ChrisW
Hi all,
I just noticed at the garage a slick on the concrete underneath the front bumper, seems to be coming from behind the driver side aux rad.
You can see the drip forming at the bottom of the arch liner. Its coming out at quite a rate!
Can I drive around with a bottle of water to top up for now until i book it in on Monday, or is putting water and not kosher coolant in the tank a definite no no in these cars?
Re: Help! suspected coolant leaking - Pic
Posted: Sat Nov 28, 2015 4:26 pm
by Grandadg90
Hi
Most likely the aux rad leaking. Its a bumper off job. Common fault. Keep an eye on your coolant level however.
Posted: Sat Nov 28, 2015 4:34 pm
by davers6
Water is fine for a day or 2
Posted: Sat Nov 28, 2015 4:54 pm
by ChrisW
davers6 wrote:Water is fine for a day or 2
I'll keep some water in the boot and get it booked into Unit 20.
Thanks all.
Posted: Sat Nov 28, 2015 5:01 pm
by Baz999
There is a diy for aux rad removal very easy to do and also taking bumper off is not hard of you are good with screwdrivers
Posted: Sat Nov 28, 2015 6:53 pm
by ChrisW
Am I right in thinking I can do away with one of the rads in favour of a CAF?
Posted: Sat Nov 28, 2015 7:58 pm
by Grandadg90
Absolutely, CAF's are a great mod. Extra noise, you will love it.
Posted: Sat Nov 28, 2015 8:03 pm
by TimDogg
Why is the CAF extra noise - sorry?
Posted: Sat Nov 28, 2015 8:07 pm
by Briggy
ChrisW wrote:Am I right in thinking I can do away with one of the rads in favour of a CAF?
Yip. £45 for the kit of fleebay and 2 hours' labour at your trusted indie if you don't fancy the job yourself. Well established mod, so no need to worry about "what ifs".
Cheers,
Bryan
Posted: Sat Nov 28, 2015 8:36 pm
by ChrisW
Thanks for that, just any of the universal ones?
like this -> http://www.ebay.co.uk/itm/UNIVERSAL-PER ... Swu-BWO1gb
Posted: Sat Nov 28, 2015 9:51 pm
by TAB1S
http://www.ebay.co.uk/ulk/itm/370782118423[url]
89mm in black i think is most commonly used :thumbs:
Posted: Sat Nov 28, 2015 11:24 pm
by MikeFish
As above, you don't want to move the actual air filter, just add a pipe to direct cold air from the fog light grill up into the air box. If you have a standard airbox I think the opening is about 89mm so that is the right size to go for, but I have the Revolution air filter kit which is open at the bottom and I found a big difference when I swapped the 89mm hose for a 102mm hose with trumpet.
Posted: Thu Dec 03, 2015 10:01 am
by ChrisW
It wasn't coolant, it was oil. The cooler pipes are goosed, goodbye £1200!
Posted: Thu Dec 03, 2015 10:11 am
by mikep99
have a read here - viewtopic.php?f=35&t=116672
Posted: Thu Dec 03, 2015 8:18 pm
by ChrisW
Bloody pipes! Fortunately the usual excellent service from Unit 20 has pulled me out of the <beep> as I'm due to go away with the misses this weekend, top work.
