Whooshing vacuum noise?
Posted: Fri Oct 23, 2015 10:53 am
by CycleSi
Since I have put the rear seats down in my B7 saloon to fit my bike in, I can hear a "whooshing" type noise like a vacuum or pump. I can't explain it very well, but it is coming from the back of the car and I haven't heard it before - only since the seats have been down.
Is it something to do with the suspension?
I'm more intrigued than concerned.
Thanks.
Re: Whooshing vacuum noise?
Posted: Fri Oct 23, 2015 11:32 am
by RichieRS
Something to do with the exhaust valves? (vacuum operated).
Posted: Fri Oct 23, 2015 11:35 am
by CycleSi
It happens constantly whilst driving.
If it were the exhaust valves I would have thought it would only be when l hit the Sport button and it would do it the once?
Posted: Fri Oct 23, 2015 11:54 am
by NJMAudiRS4
Does it do it when stationary? If so then possibly a vac leak.
Does it do it only when moving ? If so then check the boot floor for any missing grommets as a possibility. Is it the fuel pump making the noise. Any damaged seals around Windows or boot area.
Hope it's some thing simple
Posted: Fri Oct 23, 2015 5:58 pm
by Stazza80
Hi,
It might not be anything bad, on previous cars (r26 & m3) I had a similar noise with the seats down, actually sounded quite good. Amazing how much noise the seats hide from the boot area!
Ben
Posted: Fri Oct 23, 2015 9:09 pm
by Dolphie
Si,
The vacuum reservoir/solenoid valve is in the boot (I'm sure someone will correct me with the correct term). It's the blue thing that looks like 3 tennis ball spheres joined together.
I had the boot of my avant stripped out for some work and I could hear the type of noise you describe very clearly. I'm guessing the rear seats also help suppress the noise and that is why you are aware of it.
Posted: Sat Oct 24, 2015 10:08 am
by CycleSi
Yep; I think that is exactly it - the noise is to do with the vacuum system. With the seats back up it's silent again.
Thanks for all of your replies :bigwave:
