Bugger, Intake Manifold Flap problems, EPC light on :(
Posted: Tue Oct 13, 2015 9:56 am
Hi guys
This couldn't have come at a worse time but at the weekend the EPC light came on at the weekend and didn't go away. Ran diagnostics this morning and had a couple of errors with the engine have come up. Fired her up to move her for the builders, she did sound a tad funny and the check engine light is now lit up as well as the EPC light. I cleared the codes after copying them out.
I had to drive the car to the office, got emergencies to deal with. EPC light came on immediately but the check engine has not come on yet. Codes are as follows -
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H03--- Serial number:
Coding: 01040003180F0160
Shop #: WSC 00191 264 15243
VCID: 63C57505A28DA92620-8036
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141636 km
Time Indication: 0
Freeze Frame:
RPM: 3092 /min
Load: 19.2 %
Speed: 42.0 km/h
Temperature: 29.0°C
Temperature: 19.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
1 Fault Found:
008224 - Intake Manifold Flap Position Sensor (Bank 2)
P2020 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141636 km
Time Indication: 0
Freeze Frame:
RPM: 3093 /min
Load: 19.2 %
Speed: 42.0 km/h
Temperature: 28.0°C
Temperature: 19.0°C
Voltage: 13.970 V
Apologies in advance, I haven't used the search function yet, I have a client with the world's oldest server that has died and despite me telling them time and time again that they needed to replace it, they didn't and it is all my fault of course........
Will go searching as soon as I realistically have the time but any help gratefully received in the meantime thanks.
Nick.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141636 km
Time Indication: 0
Freeze Frame:
RPM: 3092 /min
Load: 19.2 %
Speed: 42.0 km/h
Temperature: 29.0°C
Temperature: 19.0°C
Voltage: 13.970 V
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 141636 km
Time Indication: 0
Freeze Frame:
RPM: 3093 /min
Load: 19.2 %
Speed: 42.0 km/h
Temperature: 28.0°C
Temperature: 19.0°C
Voltage: 13.970 V
Nick.
