Few tips needed from you..
Posted: Fri Oct 02, 2015 6:41 pm
I need some advice with the following:
1) When fitting KW Variant 3 coilovers but wanting to save the DRC stuff what should be done? Can the pipelines be left open or should
the be stuffed? If with what?
2) Have you done something with your inlets? I mean the inside to try to make it more difficult for carbon to get stuck
My mechanic suggests to add some ceramic coating.
3) When I removed the vacuum flap from my airbox it started to smoke black. Is this normal?
4) When replacing the clutch do you always also replace the flywheel?
