Brake Pads
Posted: Mon Aug 10, 2015 3:47 pm
by rs4uk
Hi Guys
Picked up a set of front brake pads today from Euro Car Parts as the warning light is on
Got home and noticed the pads don't have a sensor wire??
Do they come separate? or have a just bought the cheap pads (TRW Pads)
Re: Brake Pads
Posted: Mon Aug 10, 2015 3:54 pm
by MikeFish
Normally the sensor wire comes attached to 2 out of the 8 pads. Some pads have no sensors though. Not necessarily a cheap thing though as the Ferrodo DS2500 pads which are very good have no sensors.
Re: Brake Pads
Posted: Mon Aug 10, 2015 6:54 pm
by rs4uk
But if they have no sensors will that mean the warning light on the dash will stay on?
Re: Brake Pads
Posted: Mon Aug 10, 2015 7:01 pm
by MikeFish
Someone correct me if I am wrong but I think you need to short the wires out to make the light come on so no sensors will mean no warning.
Re: Brake Pads
Posted: Mon Aug 10, 2015 7:21 pm
by Grandadg90
Yes you need to short the wires to trick the car.
Re: Brake Pads
Posted: Mon Aug 10, 2015 8:03 pm
by Surrey Sam
rs4uk wrote:or have a just bought the cheap pads (TRW Pads)
This...
On a 1700kg with cica 400+BHP, is that really wise?
OEM Audi ones are Pagid and are different to the cheap Pagid ones you can get from Eurocar Parts as well.
Re: Brake Pads
Posted: Mon Aug 10, 2015 9:22 pm
by Harris.
Take them back and exchange them for the TRW ones with sensors . I use them with no problems
OEM Audi ones have nasty rivets in (Another thread on here ) which score the discs .
Re: Brake Pads
Posted: Mon Aug 10, 2015 9:46 pm
by lengster1
Only the original very early one pads did that.
Re: Brake Pads
Posted: Mon Aug 10, 2015 10:02 pm
by Covkiller
Fitted Ferodo DS2500's last month, they're not cheap but man are they good. Been to the ring since and they are really impressive all round pads.
Re: Brake Pads
Posted: Tue Aug 11, 2015 12:00 am
by gt2
Harris. wrote:Take them back and exchange them for the TRW ones with sensors . I use them with no problems
+1 I took trw pads off my car at the last pad change and they had wear sensors
Re: Brake Pads
Posted: Thu Aug 13, 2015 10:00 pm
by mr sagman
Also check out the Ferodo premier pads.. I have recently had them fitted along with new discs and they are fantastic.. without giving off abrasive dust that is difficult to clean and can cause damage to discs. Gave them a test around the Evo triangle last weekend and was very very impressed.
Re: Brake Pads
Posted: Fri Aug 14, 2015 12:46 am
by Rick_RS4
mr sagman wrote:Also check out the Ferodo premier pads.. I have recently had them fitted along with new discs and they are fantastic.. without giving off abrasive dust that is difficult to clean and can cause damage to discs. Gave them a test around the Evo triangle last weekend and was very very impressed.
do you have the part number for these please
Re: Brake Pads
Posted: Sat Sep 05, 2015 8:20 am
by AdrianE
Would also be interested in details on the Ferodo premier pads :)
Related question, so didn't want to start a new thread...
Am about to buy some 8 pot RS calipers to go on my S8 and the following pads are offered with them:
I've been around long enough to know that Pagid in the UK = ECP own brand made by TMD in China, but also that at some point in time some lines were still coming out of German factories for RS etc. E1 approval mark is Germany, which is at least encouraging, but they're also marked Textar which is just another TMD line. ECP don't list these any more, only TRW.
Anyone used these to know if they're more 'OEM' than cheap and nasty? Car isn't tracked and if these are as likely as not OEM in a different box then I'd run them, but if they're the fall apart at the first sign of use kind then obviously I will swerve and look elsewhere. Being R90 approved they ought to be within a set % of OEM performance....
Re: Brake Pads
Posted: Sun Sep 06, 2015 1:49 pm
by irishmike
I have a set of the ferodo premier and I find them very dusty. A lot more than OEM.
New discs are all clogged up after about 1.5k miles
