Two weeks in and time to get a few things sorted...
Posted: Mon Jul 13, 2015 10:48 pm
Well had the RS4 Cab for a couple of weeks now and very pleased with it!
Still getting used to everything, but could do with a bit of advice over one or two little "issues":
1. When the roof goes down, one of the little plastic trim pieces that slides into place (spring loaded I think), doesn't slide without being pushed by hand. It looks like one of the plastic bits on the side that slots into the groove has snapped so it doesn't slide along the groove in a straight line. Can this piece be bought separately and is it difficult/expensive to fit?
2. I keep getting warning lights flashing up for left main headlight, but when I check all lights (including the DRL) seem to be working ok. The DRL switch seems a little faulty - doesn't pop in and out any more and seems to be permanently on, could it be something to do with that?
Any help with the above would be greatly appreciated.
I can't really find anything cosmetic that desperately needs doing (the main reason I bought the car), but two simple things I am planning are:
1. Remove the ugly phone prep on the side of the dash. I realise that ideally I need a whole new centre dash, so was planning on taking it to an interior repairer and see what they can do about just plugging the holes. Would still look a whole lot better than with the phone prep on.
2. The aluminium (?) on the top of the gear stick is a little worn, and doesn't even look particularly nice. I thought a simple mod that would look good would be to (get a professional to) paint the top in piano black enamel paint along with the bit at the top of the shaft to match.
Anyone done anything similar to either of the above, and any tips/words of wisdom?
Thanks in advance
Thanks in advance
