Page 1 of 2
Headlight adjustment for driving 'en France'
Posted: Tue Apr 21, 2015 11:02 am
by mustdash
This is probably a stupid question but hey ho, I'll ask anyway.....
Does the RS4 have adjustable headlights for driving abroad, or do I need a set of stick on things from Halfords?
Re: Headlight adjustment for driving 'en France'
Posted: Tue Apr 21, 2015 11:08 am
by MikeFish
I think you can adjust the angle using
VCDS if you have adaptive headlights.
Not sure what you do if you don't have adaptives though.
by toyneg
mustdash wrote:This is probably a stupid question but hey ho, I'll ask anyway.....
you can change the headlights for Europe using Vagcomm but it isnt something i have bothered with - or the stickers for that matter haha
Posted: Tue Apr 21, 2015 12:02 pm
by jonicox
Your option in
VCDS will be for tourist mode, but like toyneg, I haven't bothered with either this setting or
Stickers.
Posted: Tue Apr 21, 2015 2:16 pm
by mustdash
What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
Posted: Tue Apr 21, 2015 2:27 pm
by GlenRS
Yes you can adjust them with
VCDS.
Here is the thread from when I asked about it
viewtopic.php?f=35&t=99198&p=548037#p548037
Posted: Tue Apr 21, 2015 4:46 pm
by toyneg
mustdash wrote:What are 'Le Plod' likely to do should I not bother (bear in mind I'm going to Le Mans so is likely to be a higher police presence).... I don't fancy being required to drain my bank account under the watchful eye of the Gendarmes....
i guess they could or would fine you but i have driven a few times over there and havent ever had any issue and i will be in France this Friday and wont bother as when i get back Monday night they would then be wrong for the UK haha
Posted: Tue Apr 21, 2015 5:46 pm
by PetrolDave
I have adaptive headlights and simply set them into Tourist Mode using
VCDS while we're on the train in "The Tunnel".
Posted: Tue Apr 21, 2015 7:34 pm
by neilparf
PetrolDave wrote:I have adaptive headlights and simply set them into Tourist Mode using VCDS while we're on the train in "The Tunnel".
Done this several times - it's simply brilliant and easy.
Posted: Tue Apr 21, 2015 9:25 pm
by mustdash
Unfortunately I don't own a
Vagcom...... So I will risk not having any!
Posted: Tue Apr 21, 2015 10:25 pm
by Trups
You got non adaptives?
Posted: Wed Apr 22, 2015 7:45 am
by mustdash
Trups wrote:You got non adaptives?
No - I've got the adaptive 'bend when you turn the steering wheel' lights....
Posted: Wed Apr 22, 2015 9:00 am
by Trups
Then it's a
VCDS job. Non adaptives have a switch inside to change the pattern
Posted: Wed Apr 22, 2015 9:28 am
by alefustec
Trups wrote:Then it's a vcds job. Non adaptives have a switch inside to change the pattern
I'm off to France Friday too, and wasn't going to bother with the stickers, I'm non adaptive lights so would love to k ow where the switch is located if it's easy to do?
Posted: Wed Apr 22, 2015 9:30 am
by toyneg
alefustec wrote:Trups wrote:Then it's a vcds job. Non adaptives have a switch inside to change the pattern
what time are you leaving for France Friday mate? Channel Tunnel?
