Page 1 of 2
Power output
Posted: Tue Jan 27, 2015 10:38 pm
by RsReilly
What's the most power that's been seen on a tuned rs4 without going down the supercharging road?
Mine is currently 338ps, would the sport cats or a cat delete pipe give much more?
Re: Power output
Posted: Tue Jan 27, 2015 10:43 pm
by JCviggen
338? Just getting it to run right should get you 40 or 50 horsepower...
Do you mean 438?
Fastest NA I've seen was with a ludicrously expensive and elaborate German ram airbox. They claimed 470-480ps and it was a very quick car.
Re: Power output
Posted: Tue Jan 27, 2015 10:48 pm
by MikeFish
You have an issue. Most likely a vacuum problem. Need to sort that out first and see what power you've got.
How long ago was the carbon clean?
With your mods and a recent carbon clean I'd expect about 440bhp. Maybe up to 450 with a cat delete. A sports cat won't make much difference if you already have the gutted precats as the standard cat is 200cell same as some sports cats (Milltek do a 100cell too though so slightly less restrictive). If the carbon clean was a year or more ago then I'd expect you to be around the 410 mark. But 338ps is well low (even with a vacuum problem). Do the valves on your milltek still work?
The most I've seen from a NA B7 is about the 450bhp mark which is pretty much the same mods you have but with no cats.
Re: Power output
Posted: Tue Jan 27, 2015 10:51 pm
by Harris.
How do you check if your engine needs a carbon clean ?
Re: Power output
by RsReilly
Apologies, that should of read 438ps
Re: Power output
Posted: Tue Jan 27, 2015 10:55 pm
by RsReilly
Carbon clean was only done in June last year, yes the valves still work perfect on the milltek, it's pretty loud, if I opt for the delete pipe then I might need to wear earplugs
Re: Power output
by MikeFish
In that case, you might get another 10bhp from going catless but thats about the limit without charging.
Re: Power output
Posted: Tue Jan 27, 2015 10:56 pm
by MikeFish
Rs4reilly wrote:Carbon clean was only done in June last year, yes the valves still work perfect on the milltek, it's pretty loud, if I opt for the delete pipe then I might need to wear earplugs
I only asked about the valves as it might be an indication of vacuum issues but now we know you have 438ps then all is good.
Re: Power output
Posted: Tue Jan 27, 2015 11:02 pm
by RsReilly
Harris. wrote:How do you check if your engine needs a carbon clean ?
You need to get your car on a dyno and get a power test done, if your figures are low then it's time for a carbon clean, unfortunately every b7 rs4 needs this done, poor design by Audi.
Re: Power output
Posted: Tue Jan 27, 2015 11:05 pm
by RsReilly
MikeFish wrote:In that case, you might get another 10bhp from going catless but thats about the limit without charging.
Cheers Mike, have you heard any with the delete pipes?
Re: Power output
Posted: Tue Jan 27, 2015 11:15 pm
by Harris.
Rs4reilly wrote:Harris. wrote:How do you check if your engine needs a carbon clean ?
Oh right , id have to find someone in Essex to do it then
Re: Power output
Posted: Tue Jan 27, 2015 11:31 pm
by obikaii
You have a place near you in Essex Harris,called AMD,go to
http://www.amdtuning.com & have a look.
Re: Power output
Posted: Tue Jan 27, 2015 11:33 pm
by Harris.
Thanks mate ,are they any good ?
Re: Power output
Posted: Wed Jan 28, 2015 12:46 am
by SinghB7
Theres a RS4 on ebay for sale currently, 480bhp n/a mrc tuned it claims. No mention of mods done however.
Re: Power output
Posted: Wed Jan 28, 2015 1:00 am
by Tile Diver
447 PS for mine!!
