How Poorly is she?
Posted: Fri Nov 28, 2014 12:44 pm
Hi all, big fan, first post.
Amazed at the wealth of knowledge on this site, so hoping you great people can help me understand how poorly my old girl is.
Had my RS for a few years now, and pretty much had a trouble free time of it... Recently replaced suspension due to DRC, but that's just one of those items I was expecting at some point during ownership.
Last 2 cold starts I've had flashing EPC light and very rough idle.... Turn engine off and on, and this disappears and car runs fine.
Have run VCDS and looks like I've got some misfiring going on across multiple cylinders... Any ideas, or suggestions? Any other diagnostics I should run to help narrow down the issue? however being a
I've cleared the codes after running the scan so will have to wait until it reoccurs.
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0090
Revision: --H03--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00664 210 87543
VCID: E3CF3155224E191
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Absolute Pres.: 990.0 mbar
Voltage: 10.668 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Voltage: 10.668 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Voltage: 10.668 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123314 km
Time Indication: 0
Freeze Frame:
RPM: 836 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 11.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.303 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123314 km
Time Indication: 0
Freeze Frame:
RPM: 836 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 11.303 V
Thanks for taking the time to look!
5 Faults Found:
P0300 - 001 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Voltage: 10.668 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Voltage: 10.668 V
000770 - Cylinder 2
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123288 km
Time Indication: 0
Freeze Frame:
RPM: 1552 /min
Load: 34.5 %
Speed: 0.0 km/h
Temperature: 6.0°C
Temperature: 9.0°C
Voltage: 10.668 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123314 km
Time Indication: 0
Freeze Frame:
RPM: 836 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 11.303 V
000776 - Cylinder 8
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 123314 km
Time Indication: 0
Freeze Frame:
RPM: 836 /min
Load: 47.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 11.0°C
Voltage: 11.303 V
