Page 1 of 2
HELP.......TPMS problem
Posted: Wed Nov 26, 2014 8:20 pm
by willywonker RS4
Hi everyone
Hope someone can help with a problem I have with my B7 audi rs4, I drove the car yesterday for the first time in 2 weeks and the TPMS flashed up red with no Amber warning just a straight red, I stopped at a garage and filled the tyres with air, one was very low 26psi not 33 so I reset it using the RS steering wheel, cleared the warning and drove off, 2 miles later it flashed red AGAIN, checked the pressures but nothing wrong, It doesn't want to stay resetted.
Please help
Re: HELP.......TPMS problem
Posted: Wed Nov 26, 2014 8:32 pm
by bluenosewrx
Sensor gone mate, prob need to replace it, AFAIK btys only last 4-5 yrs, prob best changing all 4, plenty threads on here if you search,
Posted: Thu Nov 27, 2014 12:20 am
by willywonker RS4
How much are they a pop and won't it be easier just to have someone over right this and is it ok to drive with that on the dash or will it cause more problems
Posted: Thu Nov 27, 2014 12:23 am
by rocket1
As long as you know the pressures are fine it won't cause any problems at all. You can turn the system off but not sure if you use
VCDS or can select from the menu where you set pressures.
Posted: Thu Nov 27, 2014 9:53 am
by willywonker RS4
rocket1 wrote:As long as you know the pressures are fine it won't cause any problems at all. You can turn the system off but not sure if you use vcds or can select from the menu where you set pressures.
Hi
I've tried resetting it on the display menu but it only last 2 miles then bleeps red again, I've heard u can take it to a garage with audi knowledge and if they have the software they can disable it which works out cheaper than replacing 4 sensors as I'm not sure which ones knackered
Posted: Thu Nov 27, 2014 10:06 am
by RossDagley
Anyone with
VCDS can disable it for you - don't go pay a garage! You're welcome to pop over to me (MK443AP) if you can't find someone closer to help - I'll do it for you in under 1 minute.
Posted: Sat Nov 29, 2014 1:22 am
by willywonker RS4
Hi Ross, what is
VCDS and where abouts are u to Milton Keynes?
Posted: Sat Nov 29, 2014 3:38 am
by RossDagley
I'm about 20 miles from Milton Keynes - black cat roundabout on the a1. Directly down the a421 until you hit it
VCDS is
Vagcom by another name - the software and hardware required to talk to all the cars ecu. Change settings, read codes etc
Posted: Sat Nov 29, 2014 8:00 am
by The_Coat
If you need new ones this guy should take £30 each if you put a snide offer in.
http://pages.ebay.com/link/?nav=item.vi ... 1449941807
Posted: Mon Dec 01, 2014 9:24 pm
by willywonker RS4
RossDagley wrote:I'm about 20 miles from Milton Keynes - black cat roundabout on the a1. Directly down the a421 until you hit it
Vcds is vagcom by another name - the software and hardware required to talk to all the cars ecu. Change settings, read codes etc
I know where that is, when can I pop over and how much do u want for the service m8
Posted: Tue Dec 02, 2014 1:37 am
by RossDagley
I work from home so am in most days - just drop me a PM a day in advance with a rough time and we'll hook up
No charge don't be silly - bring a packet of biscuits if you want anything with your cup of tea
Posted: Tue Dec 02, 2014 10:09 pm
by willywonker RS4
RossDagley wrote:I work from home so am in most days - just drop me a PM a day in advance with a rough time and we'll hook up
How about Thursday if your free and between 9am and 10am, I can come straight from work as I work nights so won't take me that long to get to yours
Posted: Wed Dec 03, 2014 3:01 pm
by flying_tomatoes
bluenosewrx wrote:Sensor gone mate, prob need to replace it, AFAIK btys only last 4-5 yrs, prob best changing all 4, plenty threads on here if you search,
Exactly this. This seems to be popping up on all the boards lately. I guess its just about that time.
Posted: Thu Dec 04, 2014 1:28 am
by theperm
Ive got the same issue, doing my nuts in. Can you tell which one it is on
Vagcom or is it best to just replace each corner?
Anyone used these ?
http://www.ebay.co.uk/itm/261203447212? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/301277497754? ... EBIDX%3AIT
Posted: Thu Dec 04, 2014 10:25 am
by RossDagley
Vagcom wont tell you which sensor it is unfortunately. It's a very basic tpms system.
