Wet carpet on passenger side footwell
Posted: Sun Oct 12, 2014 4:12 pm
by Patgas1
Had some serious rain here last week and not used car,give her bit of clean out today and noticed wet mat on passenger side,not sure if it looks like it has been running down bottom left plastic kick panel aaaaaaaaaaaa
Help
Re: Wet carpet on passenger side footwell
Posted: Sun Oct 12, 2014 4:20 pm
by boombastik
If your prone to parking in areas where there is a lot of trees you can often find the scuttle panel under the bonnet blocked with leafs which can cause the water to leak in to the cabin, this happened with my mates A4 all road
Posted: Sun Oct 12, 2014 5:08 pm
by Patgas1
Just took a look and no leaves.......but after investigating I'm pretty sure due to fact the car was parked on slight incline and the amount of rain I think the water has built up too much to exit out of the side drain hole and backed up and gone under the polen filter housing that's sealed from the cabin with a poxy bit of foam.......not even a proper seal what a piss poor design from audi
shocking ......carpets soaked mat took most fortunately and full of electrics under that side bloody hell.
Posted: Sun Oct 12, 2014 6:35 pm
by Patgas1
Any one else had this issue
Posted: Sun Oct 12, 2014 6:54 pm
by Audi Pardner
I seem to remember a thread some time ago on here where someone had a problem like yours and it was the T-piece take off for the rear screen wash. Can't be certain, sorry.
Posted: Sun Oct 12, 2014 7:36 pm
by rocket1
have you got a sunroof ?, if you have then sometimest he drain holes can block and the water will find its way to the car.
Posted: Sun Oct 12, 2014 7:50 pm
by Patgas1
Havnt got rear screen wash ?
And yes do have sunroof ....I have blown holes out with air line but I'm 99% sure it's what I mentioned above .....there isn't a seal between pollen filter house an body just a foam dust seal.
Posted: Sun Oct 12, 2014 9:41 pm
by Audi Pardner
Patgas1 wrote:Havnt got rear screen wash ?
Ah, sorry - I was obviously thinking Avant
Posted: Sun Oct 12, 2014 9:47 pm
by Patgas1
I will pull it off tomorrow and see if I can seal it better as I caught it just in time or could have been costly
Posted: Mon Oct 13, 2014 4:20 pm
by davers6
Had this on 2 m5's and a c5 rs6 always park facing downhill can't happen then
Posted: Wed Oct 15, 2014 9:47 pm
by rob-carp
Hi
Had it on mine, passenger side front carpet wet, watched the water trickling down the plastic trim in a heavy downpour tracked it down to windscreen seal on passenger side, shoddy workmanship when the windscreen was replaced , all sorted now,
Posted: Thu Oct 16, 2014 5:21 pm
by docurley
There are two drain points in the scuttle panel and silt can plock them up, get a old school coat hanger and straigten it out then poke the holes.
They tend to have a gromit in there and most people just poke them out also a incorrectly fitted pollen filter cover can also cause this issue.
Posted: Thu Oct 16, 2014 6:38 pm
by Rick_RS4
my missus usually has a wet carpet after shes been in the RS with me too
