B7 BRAKE LINES
B7 BRAKE LINES
any members change there stock brake lines for braided ss ? if you did was there any real improvement in brakeing. pedal feel. less fade. is this mod worth the expence in your opinion.
Re: B7 BRAKE LINES
I have braided hoses on mine but they were put on by the previous only so nothing to compare them to, sorry...
2010 911 Turbo PDK.
Gone but not forgotten... Sprint Blue B7 RS4 with all the toys
20" AG M310's | TTS Supercharged | MRC Stage 3 | Sach's Clutch | Lightened / balanced flywheel | High Pressure Fuel Pumps | KW V3's Coilovers | De-Cat + Valved Milltek | DeCoked | Launch Control | Flat Shift | Cold Air Feed Induction.
Re: B7 BRAKE LINES
In my experience i would say that fitting braided lines are worth it.skywriter wrote:any members change there stock brake lines for braided ss ? if you did was there any real improvement in brakeing. pedal feel. less fade. is this mod worth the expence in your opinion.
They are also not overly expensive.
Re: B7 BRAKE LINES
I changed form OEM to HEL braided all round (£78 delieverd) coupled with a fluid change using ATE Blue and I noticed better pedal feel and firmness.
I would say for the money involved, it's a great upgrade...
Gone but never forgotten:
- Ranger Rico
- 2nd Gear
Re: B7 BRAKE LINES
I did the same as Neil, hel all round. Tbh I don't feel much difference but maybe I drive like an old lady, I still recommend it if you have the original hoses.
Got mine done at my service where they changed the fluid, came in at 2 hrs labour as they had trouble getting the oem hoses off due to corrosion.
Re: B7 BRAKE LINES
Did you guys have any problems fitting the rears? I was advised against it as the fittings are prone to shearing and requiring new brake pipes to be fitted
Re: B7 BRAKE LINES
I have and can't say I noticed any difference really,but I did it when the car was younger and oe ones were probably tip top condition.I was surprised as I've always had a noticeable improvement on bikes I've upgraded.
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 227 guests
