Piggie Pipes (...what is this?????)
Posted: Thu Aug 14, 2014 6:03 pm
by nikkak77
Guys,
While the car was in the workshop for teh clutch issue, I had asked them to keep on the stock cat back and remove the pre-cats.
The guys there once they removed the exhaust system, instead of coming across the standard "ceramic" materail, came across the below metallic stuff inside.
Since I am the 2nd owner of the car and due to that I cannot locate the previous owner who had claimed that the car was entirely stock, do you know what it is we are looking at?
Re: Piggie Pipes (...what is this?????)
Posted: Thu Aug 14, 2014 9:30 pm
by TonyHayers
Um, that's just catalyst material. What was he expecting? ceramic floor tiles?
Posted: Thu Aug 14, 2014 9:38 pm
by rwilsonrs4
yeah thats the std OEM precats whch are the same as the ones further down but closer to the manifold so heat up faster to reduce emissions earlier ,
Posted: Thu Aug 14, 2014 9:53 pm
by nikkak77
Just noticed that i failed to describe it correctly.
Instead of finding inside after the mesh on the pics the honeycomb material, we found sth like a metallic precat.
Have you ever seen sth like that?
Posted: Thu Aug 14, 2014 10:01 pm
by bhprs4
The RS4 uses a metal cat in the pre cat. So you won't find the normal ceramic honey comb material.
To remove I used a drill to help break it up and then pulled out in bits.
Posted: Fri Aug 15, 2014 8:47 am
by nikkak77
bhprs4 wrote:The RS4 uses a metal cat in the pre cat. So you won't find the normal ceramic honey comb material.
Thanks for the tip. Had no idea.
It is now off...
Posted: Fri Aug 15, 2014 1:35 pm
by sakimano
They're basically metallic race cats. Unlike almost any other audi I've seen before
Posted: Sun Aug 17, 2014 3:27 pm
by nikkak77
I always thought - by mistake obviously - they had the honeycomb material.
I removed them and the strange thing is that i have not a CEL light.
I have driven it for a couple of days now in mostly small distances but no light at all.
I have neither added spacers on the O2 sensors nor moved them further apart.
Shouldn't have produced the warning light?
Posted: Sun Aug 17, 2014 6:37 pm
by sakimano
It will come don't worry. Can take 100 miles.
You probably already have fault codes... Maybe have a look?
Posted: Sun Aug 17, 2014 6:41 pm
by nikkak77
No fault codes in
VCDS....
Posted: Fri Sep 26, 2014 6:30 pm
by voidopolis
nikkak77 wrote:No fault codes in VCDS....
did you end up ever throwing a code or have any problems?
Posted: Fri Sep 26, 2014 8:00 pm
by nikkak77
Yes, but fixed it via a tune
