De-coke???
Posted: Sun Jul 13, 2014 5:56 pm
by theboyleach
Does it really make a difference?
My car has just turned 49000, just wondering if it would make a noticeable difference?
Simon
Re: De-coke???
Posted: Sun Jul 13, 2014 6:07 pm
by PetrolDave
theboyleach wrote:Does it really make a difference?
Do the 3000-8000rpm test, if you still do a time that's within the factory spec (somewhere in the high 8 second area) then you'll be making close to factory power so it won't make much difference.
Re: De-coke???
Posted: Sun Jul 13, 2014 8:52 pm
by harding
PetrolDave wrote:theboyleach wrote:Does it really make a difference?
Do the 3000-8000rpm test.
Sounds interesting. How exactly do i do this test? I take its best to use the lap-timer built in the fis?
Re: De-coke???
Posted: Mon Jul 14, 2014 9:10 am
by manual_daniel
harding wrote:PetrolDave wrote:theboyleach wrote:Does it really make a difference?
A very good test - lots of good information here.
http://forum.rs246.com/viewtopic.php?f= ... 0+rpm+test
Re: De-coke???
Posted: Mon Jul 14, 2014 11:42 pm
by Bladerider
Definately.
My car was making 328 bhp !!!
Now nearly 440 !!!
Re: De-coke???
Posted: Mon Jul 14, 2014 11:54 pm
by MikeFish
Bladerider wrote:Definately.
Now nearly 440 !!!
You had other issues though, a decoke won't make that much difference.
and didn't someone check their engine a year after having a decoke and found it was all coked up again? Unless you are going to have it done every year or managed to find a way to prevent / slow it down then it seems a little pointless to me.
Re: De-coke???
Posted: Tue Jul 15, 2014 12:25 am
by stu
MikeFish wrote:Bladerider wrote:Definately.
Now nearly 440 !!!
+1, feck that. I'm going the preventative route and giving my engine a good workout every time the oil's up to temp. I'm currently averaging 17-point-something lifetime miles per gallon and that's not from sitting in traffic. It's been a while since I've done the 3-8000 test but I'm fairly confident I'm not missing any horses.
Re: De-coke???
Posted: Tue Jul 15, 2014 11:35 pm
by harding
Did it today a few times! I actually landed between 8.5 - 8.8 everytime. Was actually abit worried it was time for a decoke on mine. But everything is in shape!
Re: De-coke???
Posted: Sat Jul 19, 2014 2:15 pm
by Covkiller
It makes a difference for sure. If your valves don't close due to carbon build up then you loose compression and hence power. I went from 398ps to 442ps post a Terraclean, MRC carbon clean and custom remap by Doug. I had no other issues with the car before and after, this was with standard cats a non res Milltek and everything else as stock. The car does over 193mph on the clock.
Re: De-coke???
Posted: Sat Jul 19, 2014 4:23 pm
by CycleSi
About to buy a 2007 B7 with less than 21k miles and I'm a bit concerned about this carbon build up/decoking issue.
I get the impression the previous owner looked after/pampered this car (hence the low mileage) and hasn't driven/revved it hard enough to prevent carbon build up.
I'll get MRC to do a health check.
My question is on a car with so few miles is it unlikely to be an issue?
Many thanks,
CycleSi
Re: De-coke???
Posted: Sat Jul 19, 2014 5:54 pm
by S4WON
CycleSi wrote:About to buy a 2007 B7 with less than 21k miles and I'm a bit concerned about this carbon build up/decoking issue.
Many thanks,
CycleSi
I had a car with similar mileage and had no problems at all. Like you say though, it's more to do with how it's been driven rather than the mileage. An MRC health check ( and a regular "Italian tune") sounds like a great idea and if you get anywhere near 390 bhp, its a good 'un.
Re: De-coke???
Posted: Sat Jul 19, 2014 6:44 pm
by CycleSi
Thanks for that.
As I say, I'll get MRC to check it out and hope it's in fine form before thinking about a Stage 2 remap.
