Page 1 of 2
Cold start - mornings
Posted: Thu Apr 24, 2014 1:36 am
by WilkinsonRS4
Why is it RS4s are crappy from morning cold starts!?
I've got mine remapped and I turn the engine on first thing in the morning and I've got to wait 20/30 secs before the revs calm down before I can pull away, even then it drives lumpy till you get going, why are these machines so bad early in the morning!?
Re: Cold start - mornings
Posted: Thu Apr 24, 2014 6:54 am
by Rw@@dy
Mines exactly the same so your not alone lol
Posted: Thu Apr 24, 2014 7:13 am
by sync24
What map (if any) are you running - My MRC stage 2 runs fine from cold - a little lumpy but definatley usable immediately post button press. Have you had the coilpacks replaced?
Posted: Thu Apr 24, 2014 8:09 am
by John Johnson
Mines not lumpy
Posted: Thu Apr 24, 2014 8:19 am
by rallyewill
I'd get that checked out, mine runs spot on when cold - defo an issue there. Even if it was mapped, it shouldn't affect the cold start.
Posted: Thu Apr 24, 2014 8:25 am
by neilparf
Mine before the stage 2 MRC map and after cold starts were and are just fine. If anything, the map has made it slightly better; the cold start 20-30 second wait is almost non-existent. Coil packs maybe?
VCDS scan and maybe get it checked out. What map do you have if any?
Posted: Thu Apr 24, 2014 10:06 am
by toyneg
sync24 wrote:What map (if any) are you running - My MRC stage 2 runs fine from cold - a little lumpy but definatley usable immediately post button press. Have you had the coilpacks replaced?
+1 the MRC Stage 2 with quiet start mode seems to be pretty decent from cold
Posted: Thu Apr 24, 2014 10:28 am
by MikeFish
Mine seems fine most of the time because by the time I drive off the driveway/manoeuvre out of a space it is fine. However, when it is cold (engine and outside temp) and I pull straight out of a car park space it does stutter and hold back a bit. By the time I get to the exit it is fine or if I had to reverse or 3 point turn to get out of a space first it is warmed up by then and fine. It literally is the first 10 seconds of turning on. Only ever noticed it after my remap. I assumed it was something to do with the SAI that I had removed at the same time.
Posted: Thu Apr 24, 2014 11:41 am
by Marten
It could be that the lambda sensor(s) is(are) done. I had one replaced and car runs much smoother on cold starts. I also get little better mpg than before.
Posted: Thu Apr 24, 2014 12:16 pm
by Covkiller
Mines fine pre and post MRC cold start map.
Sounds like you have a problem. Take it back to whoever mapped it.
Posted: Thu Apr 24, 2014 12:45 pm
by MikeFish
Do any of the people who say their cars are fine have their SAI removed? And do you pull away immediately from a cold start within 2 seconds of it starting and not crawl away? Like I said, if I'm parked in a space or on driveway I'd never notice it so some of you might just not have noticed because of where you park.
Posted: Thu Apr 24, 2014 1:15 pm
by neilparf
MikeFish wrote:Do any of the people who say their cars are fine have their SAI removed? And do you pull away immediately from a cold start within 2 seconds of it starting and not crawl away? Like I said, if I'm parked in a space or on driveway I'd never notice it so some of you might just not have noticed because of where you park.
Mine still has the SAI - I pull away after the 10 seconds and its fine. Having said that, I've pulled away immediately and never noticed it to be lumpy or difficulty... I think the MRC stage 2 map helps a lot...
Posted: Thu Apr 24, 2014 2:11 pm
by KernowPete
Mine's standard but I've never had a problem. I just wait for the fast idle to drop back then drive away and everything's fine.
Posted: Thu Apr 24, 2014 2:22 pm
by V8mark
Could be the ecu software update is needed here???
Posted: Thu Apr 24, 2014 3:18 pm
by coffey555
My one used to run a bit rough on start up until I changed out the PCV valve.
