Ceramic brakes
Posted: Mon Nov 18, 2013 7:15 pm
by harding
There is a beautiful white edition RS4 2008 for sale in sweden, and i want to go and look at it. It has 100.000km on the meter - so im just wondering, when is it time for the brake change on the ones with ceramic brakes? Ive been told the price tag on changing the disks are about £4500? True, false?
Re: Ceramic breaks
Posted: Mon Nov 18, 2013 7:35 pm
by PetrolDave
Brakes are what stop your car, break is what your car does when your brakes don't work
In some countries I believe that Audi offer a 150,000km warranty on the ceramic discs.
Re: Ceramic breaks
Posted: Mon Nov 18, 2013 7:50 pm
by barryrs
From recent posts and having covered 100k kilometers they will be a liability IMO and I would allow £5k plus for a new set.
Re: Ceramic breaks
Posted: Mon Nov 18, 2013 8:07 pm
by harding
PetrolDave wrote:Brakes are what stop your car, break is what your car does when your brakes don't work
Hahaha sorry, my bad. I thought all the way something wasnt quite right.
Thanks for the info you two!
Re: Ceramic brakes
Posted: Mon Nov 18, 2013 8:49 pm
by HYFR
100km is how many miles??
If its just road use, they will be more than fine...it depends how much hard track use they have had...
Re: Ceramic brakes
Posted: Mon Nov 18, 2013 9:36 pm
by rocket1
62k miles
Re: Ceramic brakes
Posted: Mon Nov 18, 2013 10:49 pm
by jonicox
Audi reckon that the discs are good for 300,000km under normal driving, but as D_K says, this is likely to be a bit shorter if tracked.
Re: Ceramic brakes
Posted: Mon Nov 18, 2013 11:28 pm
by Teutonic_Tamer
In the UK, the ceramic discs retail at about £2100 each. SGL Carbon, who make the discs for Audi (as well as for Porsche and Lambo) state the service life is 150,000 miles. As for wear - they don't wear in the conventional sense, they degrade and loose mass when overheated. So they should really be weighed to determine when they need replacing.
Re: Ceramic brakes
Posted: Tue Nov 19, 2013 11:12 am
by HerbBerb
Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
Re: Ceramic brakes
Posted: Tue Nov 19, 2013 11:26 am
by jonicox
cheese666 wrote:Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
I think you will need to change callipers as well as the ceramics are a different diameter. Probably bits of coding to do as well to let the system know you have changed.
Re: Ceramic brakes
Posted: Tue Nov 19, 2013 12:18 pm
by Teutonic_Tamer
Diferent discs, differnet pads, different calipers, different splash shields.
Audi do an official retro fit kit containing all the bits you need (except the splash shields), including a CD-ROM with a few pdf documents on there. Part number is 8E0 098 203. Make sure a sturdy seat is nearby when asking for the price thou!
Re: Ceramic brakes
Posted: Tue Nov 19, 2013 2:17 pm
by Surrey Sam
Teutonic_Tamer wrote:cheese666 wrote:Apologies if this has been covered a million times but, is it a straight forward swap to standard discs on a car fitted with ceramic ones when they are ready for a change?
TT - Is that not the Ceramic retrofit kit, I read the question as swapping back to the steel setup? From reading your historical posts I see that you're a stickler for correct information, so wouldn't want any duff information out there?
