Drc to coilovers.
Posted: Sun Sep 01, 2013 9:16 pm
by Garethtdi100
Really sorry if this has already been explained. I'm having problems with my Drc so I've ordered a set of H&R coilovers. Is this a simple change over or do I need to have the ecu adjusted or buy some extra kit?
Thanks Gareth
Re: Drc to coilovers.
Posted: Mon Sep 02, 2013 6:59 pm
by PetrolDave
Garethtdi100 wrote:Is this a simple change over or do I need to have the ecu adjusted or buy some extra kit?
DRC is 100% mechanical, there is no ECU
Posted: Tue Sep 03, 2013 6:58 pm
by Garethtdi100
Thanks for your reply. I take it you just disconnect the pipes from the shock and forget about them?
Posted: Tue Sep 03, 2013 7:07 pm
by PetrolDave
Garethtdi100 wrote:I take it you just disconnect the pipes from the shock and forget about them?
Someone who has replaced DRC will have to answer that, I'm still running DRC.
I just love the assumption that DRC is connected to the (electronic) diagnostics - you're not the first person to make that assumption (and won't be the last I suspect).
Posted: Tue Sep 03, 2013 7:21 pm
by Garethtdi100
I just wandered as I seen on a dealers website about a "DRC cancel kit". My mechanic is working at the car now so ill update this shortly. This is the site i seen it on.
http://www.awesomegti.com/car/audi/rs4b ... pe-qb6-4wd
Posted: Wed Sep 04, 2013 8:03 pm
by Dal
Garethtdi100 wrote:Thanks for your reply. I take it you just disconnect the pipes from the shock and forget about them?
Exactly that, leave it all intact just disconnect the shocks from the system and leave in situ..
