Rear Discs for £32.86!
Posted: Wed Jul 24, 2013 6:39 pm
by jdwoodbury
Re: Rear Discs for £32.86!
Posted: Wed Jul 24, 2013 6:54 pm
by Noyjatat
Those are most definitely not what you want for your B7 RS4!
The rear brakes are drilled, vented and floating 324 millimetres (12.8 in) by 22 millimetres (0.87 in) iron discs, with gloss black Lucas-Girling TRW single piston floating calipers with an integrated mechanical handbrake mechanism.
This is what they should look like! Pic 2 of 2
http://www.stokeaudi-parts.co.uk/produc ... ct_id=1190
Posted: Wed Jul 24, 2013 7:29 pm
by brn7y
Those are the fronts
by Rick_RS4
rear disks are not floating they are 1 piece, pic above is of front disk? but you are right they are 324 x 22
Posted: Wed Jul 24, 2013 7:46 pm
by Noyjatat
Go to pic 2 of 2 boys, I did put it in the thread. Unfortunately it automatically puts up pic 1. I do try.
As for floating, my bad just copy pasted from Wiki. Just trying to stop someone from buying those discs thinking they were getting what they have fitted.
Posted: Wed Jul 24, 2013 7:51 pm
by MikeFish
Gaz is right, pic 2 is the rear disc.
That eBay one is a solid 255mm diameter and only 12mm thick!!! That's a big difference!!!
Posted: Wed Jul 24, 2013 8:21 pm
by pDkALO
Never ceases to amaze me some of the dodgy tat being openly sold on fleabay - if you go on there and search for less than 5 mins you'd be convinced that you could replace discs and pads front + rear on a B7 RS4 for about £150.... which as we all know, is never going to happen
It's clearly the totally wrong parts, but loads of them are up for sale day in day out
Posted: Thu Jul 25, 2013 10:50 am
by victor2vt
Read their disclaimer at the bottom, as always, READ THE small print !!
Posted: Thu Jul 25, 2013 11:33 am
by TonyHayers
Are we sure the OP isn't being sarcastic? note the wink.
Posted: Thu Jul 25, 2013 11:35 am
by sync24
I posted this link a while back - yawn
Posted: Sun Apr 27, 2014 6:28 pm
by TAB1S
Im sorry i know its been covered but how can they be wrong?
http://www.ebay.co.uk/itm/160974940721
It says 3 have sold so people have tried them, anyone???
Posted: Sun Apr 27, 2014 10:04 pm
by Surrey Sam
The picture on the box depicts them as solid faced discs and as you'll probably be aware - the rears on RS4's are drilled. Then there is the overall diameter; the ones on the eBay advert are described as 300mm whereas I believe the rear OEM discs OD (outside diameter) is 324mm from memory. Lastly there is the manufacturer?
Trying to run an RS4 on a shoe string budget is only asking for trouble, rather you than me.
Posted: Sun Apr 27, 2014 10:14 pm
by Robnic
These will cost you - the return postage for your credit because they don't fit
