Any one know the price on the valves in the rs4 wheels
Posted: Tue Mar 12, 2013 11:46 pm
by Jamiestanton
The valves in the rs4 wheels are ones that tell the computer if there flat I have had my wheels refurbed and don't want to pay dealer prices if there £££££££
Re: Any one know the price on the valves in the rs4 wheels
Posted: Tue Mar 12, 2013 11:58 pm
by AndyJE
Yes, I just had all of mine changed at the dealer due to corrosion - they were £13 each + vat, I think...
Posted: Wed Mar 13, 2013 12:17 am
by Madmonkee
If its the TPMS sensors we are talking about your looking £75+ each, unless you buy an unknown make from ebay.de
Posted: Wed Mar 13, 2013 12:57 am
by MikeFish
There is 2 parts, the sensor inside the wheel and the valve that connects to the sensor and it the bit that you connect the pump to, to inflate the tyre. The sensors are quite expensive but can be had on ebay for about £100 odd but be warned they have batteries in them that cannot be replaced once they go flat, so if you buy a set that are 5 years old and the battery dies a week later you need to bin them and buy another set.
The valves are about £20 each on ebay. I bought a set of 4 for £75.
by MikeFish
Or you could disable the TPMS using a
VCDS cable and go old school and check your tyre pressures manually.
Posted: Wed Mar 13, 2013 6:33 pm
by Jamiestanton
MikeFish wrote:Or you could disable the TPMS using a VCDS cable and go old school and check your tyre pressures manually.
Yeh but can this defo be done if yes I will
Posted: Wed Mar 13, 2013 7:08 pm
by adsgreen
the sensors (assuming new) don't discharge until they are exposed to a certain pressure (guessing about 15psi).
Thats when the clock starts.
Posted: Wed Mar 13, 2013 7:15 pm
by u2usual
I have an extra set of sensors if someone is interested.
Posted: Wed Mar 13, 2013 7:43 pm
by MikeFish
Jamiestanton wrote:MikeFish wrote:Or you could disable the TPMS using a VCDS cable and go old school and check your tyre pressures manually.
Yes, you subtract 512 from the value of channel 61(need to double check the channel number) on the instrument cluster.
Posted: Wed Mar 13, 2013 8:04 pm
by PetrolDave
MikeFish wrote:Jamiestanton wrote:MikeFish wrote:Or you could disable the TPMS using a VCDS cable and go old school and check your tyre pressures manually.
See
http://wiki.ross-tech.com/wiki/index.ph ... 8ED/8HE%29
Posted: Thu Mar 14, 2013 1:14 pm
by MB2
adsgreen wrote:the sensors (assuming new) don't discharge until they are exposed to a certain pressure (guessing about 15psi).
I was told they had G sensors in them so are only active when the wheels are in motion, although the battery will clearly have a finite life, a set that has been sitting around even after some use may not be such a bad bet if has been "dormant" most of the time.
Posted: Thu Mar 14, 2013 1:34 pm
by adsgreen
MB2 wrote:adsgreen wrote:the sensors (assuming new) don't discharge until they are exposed to a certain pressure (guessing about 15psi).
yes they do but even g sensors need power
Theres a mechanical switch that when the pressure is raised breaks and connects the electronics to the g sensor.
So the storage shelf life is actually really really long... but as soon as they are fitted then you are on a fixed lifespan (give or take).
Now if you could mix in self winding mech from some expensive watches you cuold have ones that neve need changing...
Posted: Thu Mar 14, 2013 3:56 pm
by MB2
Oh that is sophisticated - I assumed the "G Sensor" was just a weight that got spun out & completed the circuit. Given I paid over 600 to service a mechanical watch earlier this year I think our TPMS is better left as disposable technology although to be fair the watch was still keeping time so maybe would be OK in a TPMS !
